the invoice says... labour fit new front wheel bearings both sides: 4.5 hrs =$450.00...wheel bearing kit x 2 = $190.00...hub gaskets x 2 = $9.30... autoplex grease x 1 = $29.95... subtotal = $679.25... labour to remove panhard rod, remove and replace upper and lower bush, adjust and refit as required. remove castor plates and radius arms, remove and press in bushes. refit arms and castor plates as required: 4.5hrs labour = $450.00... nissan panhard rod bushes x 2 = $45.60... genuine radius arm bush front x 4 = $244.20... wheel alignment = $75.00... subtotal = $814.80... grand total = $1494.05... yours truly MANNELL MOTORS...
a few questions
1. 4.5 hrs labour x2 = 9hrs, so they worked on your 4b for 9 hrs straight without any break.
2. autoplex grease x1, so they used a whole tube/tin on your 4b or are you paying to restock their shelves.
3. wheel alignment $75, I would question that price, should only be around the $35 mark.
4. I would also question the time it took them to do the work, should not take anywhere near that time.
