Brains Trust, I run my fridge in the tray of leaf sprung 4wd... needless to say corrugations hammer all vehicles, particularly leaf sprung (lovely when loaded mind you). Anyway, I fitted 4 x 10mm foam pads under each of the feet of my 75litre fridge as a means of elevating it a tad, and in theory giving it some protection from corrugations. I notice that the fridge sitting on flat ground that now it can be "wobbled" a bit (owing to the fact there's 10mm of foam on it) whereas before it say very steadfastly.
I am now actually wondering if having this 10mm foam / flexible mounting would actually make corrugation / rough road impact on the fridge WORSE, than if it was sitting hard against it with no such rubber/foam feet ... because the fridge itself can "wobble" additionally to the vehicle and get some vicious double slapping happening ... sort of like how antenna's snap more frequently on bull-bars that are rubber mounted (a lot of factory bullies can be "wobbled")
anyone who's explored into the foray of corrugations / rough roads / vehicle dynamics / reverberations got opinions?
My last fridge I had a whole sheet of foam under it, this new one will just have foam under the feet.
The actual fridge is securely mounted at each corner with heavy duty ratchets/tie-down, and she does not move (but of course vibration is a different story).
Thoughts?
Thoughts?
