considering pajero swaybar removal
2freeq
i am considering removing the front swaybar of my 93 nh pajero. anyone done this already on a pajero? should i remove the rear swaybar also? is it not recomended on a pajero? any answers are greatly appreciated.
PAJ
Rip the front one off makes next to no difference on road. I'd leave the rear on for the moment but.
2freeq
hmmm i might try that and take it for a drive. i read else where if i take the front off it to dangerous to drive, so leave front on and remove the rear one...... trial and error i guess
Jeep_jk112
hmm from what i've read you'd be insane to remove the front swaybar completly...
Not sure about pajero's but jeeps have front swaybar disconnects, so that we can use all tha extra flex up offroad whilst reconnecting the swaybar and not kill ourselves on road.
Have heard various opinons about removing the rear swaybar also..
Jarh73
Just keep in mind that on a vehicle such as a Pajero with independent front suspension the sway bar is quite important. For most of your driving you could live with it but if it comes to a situation when you need to change direction in a hurry to avoid something not having a sway bar dramatically increases the chances of rolling over.
Patrols for example can easily get away with no front sway bar due to the front suspension design having inherent roll stiffness. The Pajero front end does not have this.
Justin
dudelux
I had a 4runner before I got the Lux, and I took the sway bars off front and rear, it had IFS and coil rear.
I noticed a little bit extra body roll onroad, and a bit extra flex offroad.
I never drove it like a race car, and had no dramas onroad.
Jarh73
I dont have any sway bars but coils allround. she aint the commodore!
Yeah again though your front end has inherent roll stiffness. Although its probably not as stiff as a Patrol which is why Cruisers tend to flex a little bit more.
Justin
PAJ
Meh, it's a Pajero. Its as low as a commonwhore.....:D, did mine ages ago, no difference on road, but leave the rear on unless your really into the rough stuff. Being IFS all it does is give you a bit extra wheel travel, keeps the wheels on the ground longer when swerving :rolleyes:,,
As said above, you drive it like a 4wd you will be fine, drive it like a racecar which it ain't you'll have issues.
allanmac
I have removed both & does take some adjustment to driving style as it now handles like a Patrol.....;)
Seriously, it changes the dynamics of the vehicle dramatically. Steering imput must be very smooth & if you start being jerky taking '2nd grabs' (for want of a better word) with your steering, it can be disconcerning. I find that you must enter a corner at a lower speed, gently turn in & let the car have its body roll, then hold it through the corner. Once you get used to it, there is no problem. On windy roads with constant change of direction it can be a total 'pita'....:(
I might add, it does make a huge difference off road though......:D
Jeep_jk112
Its those reasons i have decided to leave my rear sway bar connected and get a set of quick discos for the front, might chuck one of these in the rear eventually though (when everything else is done)4x4ROCKSHOP.com
I tend to drive mine like a race car from time to time:D
Its got a fully sick turbo bro so its meant to be driven like that yeh?:rolleyes:
OIIIIO
just do it that extra flex will make it a bit easier for me to pull you out lmao. i bought disco's for my jeep but the mounts rub on the tyres near full lock and i lost a pin first corner so the bar is permently discoed now. It drive like a tinny up a creek on the road but is much nicer offroad.
2freeq
yep the front swaybar is coming off this weekend, if it still drives ok-ish i`ll rip the back one off to.
its a 2.5ltr diesel so there is no driving like a racecar anyway....
worst case scenerio i`ll put them back on.
2freeq
removed the front swaybar today, it does have a little more body roll on the front but not to bad, alot smoother to drive not so rigid now. i`ll try it out over the next week and see how it goes.
here is a couple of pics putting a wheel up on a little mound just to try it.
OGJON
Just take them both off it makes no difference well that's what I've found with all the 4boes ive had
