Companion 2 Burner High Output Stove & Colman bottles using UNEF to 3/8" BSP Gas Cylinder Adapter
pksharma
Hi,
My apologies if I am asking things incorrectly as I just started camping.
I like Companion 2 Burner High Output Stove https://www.snowys.com.au/2-burner-high-output-stove but does not have the roof tray to carry the GAS bottle on the roof.
Have two young kids as a passenger so not sure should carry the gas bottle in the car.
Was thinking to use these small Coleman propane bottles I could carry in the car (again not 100% sure)
Googling found out UNEF to 3/8" BSP Gas Cylinder Adapter https://www.snowys.com.au/unef-to-38-bsp-adapter.
But Snowy site and Companian says don't use any adaptor with that high-pressure stove.
Please help!
Kind Regards,
You won’t get the pressure that you get using a 4.5/9.0 kg bottle, but no reason why not. I use a similar adaptor to run my Weber baby Q on Coleman bottles with no issue. Just takes a bit longer to get hot.
I have run a similar cooker ( primus) off those gas bottles with no problems at all so cant see why not.
Just on your cooker selection. It is personal preference but I like the type that have a skin just under the burner face so that you don’t have all the nooks and crannies to fill up with crud and fat. Much easier to keep clean
For those asking about the Coleman connector.
it is 2 adapters fitted together. First one in POL to 3/8, second one with the tap is 3/8 to Coleman.
