BIGCOL
Hi everyone,
I thought I would share with you some details of Jen and my Kayaks. Here they are on the roof of my old Pajero and on my current Mazda BT50.
They are Viking Nemos, 3.2 metres long and weigh just under 20 kgs. They have three hatches for storage, rod holder holes on each side and a grab rail cord. We choose these as they are very stable and can be carried and lifted on and off the car by one person. Its a bit easier now on the BT50 as the cradles are a bit lower than the Pajero.
As you can see I have modified them to take Electric Motors (Minn Kota, 5 forward and 3 reverse gears) I installed a plate to take the sealed 75 amp hour heavy duty batteries which sits just behind the paddler/operator. (The batteries weigh about 25 kgs)
Jen has flipped the Kayak a couple of times and the strap I use to hold the battery in place has worked perfectly. A sigh of relief from me re the batteries, Jen can swim pretty well so she was ok Ha!
I then manufactured heavy gauge aluminium plates and mounted them to the rear sides to take the pivoting motor mount. Viking do sell a Kayak already set up with the mount but it is a larger Kayak and one not suitable for us.
One major issue I had in setting this all up is how to operate the motor, changing gears (Acelerating) and changing direction as in turning, when it is all behind you. I over came this by sliding a PVC pole over the handle (I heat moulded the PVC to the shape of the handle) I then hold it in place by running a bit of duct tape over the join. You just twist the tube to change gears and then swing it to whatever side you want so it will turn, (Bobs your Uncle!)
I also have flexible Solar panels that I can directly charge the batteries with but I have found that if you charge the batteries up before use, they stay charged for days. It does depend on how many hours you use them and at what speed your going at but with sensible use you would get quite a few hours each day for maybe a week before you may have to charge the batteries.
The motor makes the Kayaks fly, we get many comments as we cruise past campsites going upstream and just sitting there, doing nothing and powering along. They give us heaps like thats not Kayaking, lazy buggers etc etc all said in good humour. I just point to my head and say as you get older you’ve gotta use more of the grey matter and less of the physical stuff (Paddling)
We don’t use the motors all that often but when we do they are just fantastic. This is them without the motor and batteries, they sit a bit higher in the water.
Regards from Col.
Regards from Col.
