Colorado h/d clutch
Trav1026
Hey everyone currently putting a heavy duty clutch in my 2011 colorado all bolts are undone should it be a fight to get the box to separate from the engine?
BOUNCY HJ61
YEAH, They Can Be.
The Box Gets Tight To Separate On The Locating Dowels, And The Weight In The Spigot Bearing From The Input Shaft. Some Times Needs To Be Pried With A Pry Bar, But First Put A Bolt Back In Half Way, Then Shake And Pry. But First Always Check You Haven't Left A Bolt In Somewhere.
Cheers Michael
P.S And Welcome To Earth!
muc the truck
do the master and the slave at the same time . normaly the seals soften on the edes and make the fluid black . Atleast this way you will be confindent in the car. When ever i do a clutch both the slave and master are done too same when i rebuild a gearbox.
