colorado and dmax and rodeo diff lockers.
muc the truck
2012 Dmax Colorado Front Diff Locks
I was just looking on the net and discovered what I thought was the case is true.
If you own a 2012 holden Colorado
you can use any diff lock advertised for a
2004-2012 chev Colorado
2004-2012 GMC CANYON 4X4
2005-2010 HUMMER H3
Because they al use the GM7.625" 7-5/8" IFS DIFF.28 SPINE
The lockers also fit the gm7.5 according to this http://www.summitracing.com/parts/dtl-162c59a/applications/?prefilter=0
and this
http://www.summitracing.com/parts/dtl-912a317/applications/?prefilter=0
and this
Eaton 912A317 - Detroit TrueTrac Locker - GM 7.5" / GM 7.625" 28 Spline (3.23 and Up)
You can also cross reference rodeo and other brand vehicles with this world list . http://www.arb.com.au/media/products/air-lockers/application_chart.pdf
Oh really?
This is good news. How sure are you?
I've got a 2007 Rodeo and spoke with some from Eaton Australia last year about their e lockers. They told me they didn't have one available then but they would by the middle of this year.
I haven't followed this up as I can't afford one at the moment.
muc the truck
Oh really?
Your cars not just sold here, the diff is not local and exclusive to Australia.
did you take the time to read the information on the links including what was in the usa arb airlocker catalogue?
every other brand including copies, the choices are world wide and you are now not restricted to local pricing. this has to give you more scope into what price range you can afford as its the same as the American trooper and amigo
once you Google part numbers the various vehicles you find they share the same diffs. this means they share the same parts. Manufactures are lazy they don't re invent the wheel unless they have too. Therefore the same dif gets used in many cars all over the world , sometimes the front diff, some times the rear. Read the links and see your self.
muc the truck
Finally they have woken up and realised the diffs are the same and now advertise a stack of vehicles that now are available with a elocker. jackaroo, Colorado , dmax , frontera , mysterious utility. they took there time , I cant count how many emails I have sent them
HARROP | 4wd
PRODUCT DESCRIPTION
The ELocker’s electromagnetic locking mechanism is the latest generation of aftermarket differential technology. Performs as an open differential until you decide that you need more traction. Harrop / Eaton ELocker are your push button solution to almost any traction problem.
Designed expressly for 4-wheel drive systems to give you the ability to lock or unlock the differentials when necessary. When locked the Harrop / Eaton ELocker performs as a full locker, capturing 100% of available torque and sending it equally to both ends of the axle.
The ELocker is built with precision-forged gears that are designed to mesh perfectly, providing improved strength and durability over a standard cut gear. Its ease of installation, reliability and push-button activation make ELocker an absolute must for all traction and off-road performance applications.
Product Code: 99-ELKR11556
VEHICLE APPLICATION GUIDE
◾Isuzu D-Max, Years 2012- onwards, IFS suspension, 17 spline
◾Isuzu D-Max, Years 2008-12, IFS suspension, 17 spline
◾Holden Jackaroo, Years 1988 - onwards, IFS suspension, 17 spline
◾Holden Rodeo, Years 1988- onwards, IFS suspension, 17 spline
◾Holden Colorado, Years 2008-11, IFS suspension
◾Holden Frontera/Sport, 1990 - onwards, IFS suspension, 17 spline
gubarb
Hi
Just googling and found your post on the elockers, Just be careful as I tried my luck and ordered one from the states for the rear of my RG Colorado but it didn't fit. They are AAM 860 rear and AAM 760 front the rear didn't fit because ours is a banjo and the US version is a salsbury with the rear cover. As for Harrops I believe they have modified it to fit the Oz version.
In saying that the front one from the US may fit as I think it's the same as ours.
vnformula
2005-2010 HUMMER H3
and this
and this
Following those links for the arb page they list different part numbers for usa colorado and aus colorado? Are you sure they are the same? I would love a auto locker for the rear of my 08 collie
dirvine
I used Summit racing for my (don't laugh) Great Wall, way back in 2011. They were of great help, and did measurements for me so make sure that my 8" Toyota rear style diff would fit the auto locker I wanted. It is a case of not just accepting everything is the same because the name is the same, but helpful people in Australia will provide you with sufficient info to make inquiries overseas. I used the Diff Doctor (lives in Hallam) to help me out. As a result, I got the genuine article (Detroit) and it fitted first go. I think you all know my opinion of Harrop quality and his helpful advice.
