Colorado 7 protective plates
rj1952
TJM at St.Marys, SA , fitted my two Brown Davis underguards this morning. This was the first time they have fitted these to a Colorado 7 and it was almost straight forward.
It turns out that the front underguard didn't quite allow for the Holden Steel Bullbar support brackets, so a little impromptu cutting was required on the top edge of the guard.
All done now, and it looks really solid.
I only fitted this extra protection because I read an article of a comparative test between a standard Colorado 7 LTZ and two modified Pajeros. The Colorado 7 did all that the Pajeros did, but one of the Pajero owners commented that he thought the transmission of the Colorado 7 was vulnerable to rock damage .. I believe they were testing in the Victorian Alps. My LT model is lower than the LTZ, so I thought it was worth a bit of extra protection since I expect to be in the Flinders Ranges a fair bit in the coming years.
[Would you believe that in the evening of the very day I paid a deposit on these steel guards, I read a thread re. an over-heating Toyota ute, in which the suggestion was made that non-standard engine underguards had mucked up the original designed air-flow, and caused this heat issue. Here's hoping my Colorado 7 stays cool!]
:eek:
Next Monday I am booked in at Opposite Lock for a 40 mm Tough Dog lift - should give me that extra clearance I seek :D
