Coiled, Live axle, Mazda Bravo 92
Bainsy
Coiled, Live axle, Mazda Bravo, 92
Good Points
Dual cab, wide wheel track, low centre of gravity, no IFS, somthing diffrent :D
Bad Points
Expencive engineers report.
What mods have you done?
Patrol diffs/axles, coils, 3" lift, 35" goodyear wrangler m/t's.
LS1 chev, turbo 700, 37" pro comps or maxxis, 4 link rear, air lockers, front and rear winches, tray/cage, lots more.
Why did you buy this vehicle?
Didnt buy it, im building it!
How often do you go offroad?
As often as i can.
could be anything!
Here it is when i first got it stock standard
Here it is with a SAS, patrol diffs and a little suspension upgrade!
It sits a wopping 2050mm wide and only 1870 high on 35's and 3" lift and im still able to lower the cab by 30mm. Almost level roof height of a stock patrol or cruiser!
Bainsy
Pics should be up in the next week or so. Thanks matt ill get onto ya about the drive shafts and steel for the 4 link rear end when im setting it up.
Big Matt
To easy mate :)
Are you going to keep this one lower ? Would be a good truck to keep the height down on being fairly compact to start with
Bainsy
Yep low and wide is the plan. Only 3" lift. Chopping the hell out of the guards to make 37s fit. Should see the tunnel i have to make to fit the turbo 700 and gq transfer case in! The seats will be almost toutching the doors! Drivers side seat may need to be raised and sliding railed removed. Gonna be fun fun fun!
Big Matt
are you going to try and engineer it, if so can i watch LOL or track toy ?
3" lift and 37's would make it similar height to standard patrol wouldnt it ?
Bainsy
Yeah iv alreay contacted an engineer about it. And yeah 3" with 37s the roofline should be similar to a patrol.
Bainsy
Nah not engineering 37's just the engine, driveline, suspension and passenger compartment. Then add lockers, tyres and go any where bits to it once its engineered.
oznog05
Hay Bainsy, I reckon you paint it yellow and pink and put flower sticker all over it!....lol
Sounds like you have you're hands full mate, still waiting on pics too!
Have did you go with ya shed too!
Bainsy
Sheds up! Shire signed it off today actualy so i might extend it soon. Should have pics by end of the week. Im going to put on the 35's with the fliped and 50mm backspaced cruiser rims. Man its gonna be W I D E!
Bainsy
Big Matt
Nice, wouldnt have thought it would look that good :)
Definantly drop the cab, you think your going to have much issue with the tires rubbing the chassis on flex ?
Bainsy
I can only drop the body another 30mm but i need to do some body modiforcation first! :D And theres no way the tyres can hit the chassis unless somthing breaks.
