clutchless gear changes
hiluxdriver
Hi All,
I have been doing clutchless changes in a variety of different cars I've owned for a while now and just want to know is it doing any damage to the clutch/gearbox internals? My Patrol does them quite easily at just above 1000rpm which is great when I'm crawling along in Sydney traffic, but most other vehicles it has been a nice easy slip in much higher in the rev range. I have no idea when it comes to gearbox syncros and so on, so advice is welcomed.
Thanks
Jase
:D :D
Traveller
I use the clutch in my patrol, but have been a bit lazy using them in semi's.(road ranger boxes)
Have done various training/tests/etc over the years and most instructors say the clutch is there for a reason, use it. It's far cheaper to replace a clutch than a gearbox I guess...
frosty
What he said! Why wouldn't you use it? Syncro boxes are pigs to change without disengaging them. And they just aren't heavy duty like an Eaton. Knocking out of gear is not so bad, but plucking the next one is just doing damage. Gears and selectors.
Patrick Albrecht
Great skill to know if your clutch ever plays up, as everyone said it is there use it, unless you have deep pockets, then you may as well change to a auto
no issues with doing this as long as it is done properly. This is called Rev matching. This will NOT damage syncro's but i state as long as this is dont properly!!!
Jarh73
You speak the truth!
As long as you do it properly no damage.
Justin
muc the truck
when gear changes become notchy especialy 1st to 2nd the damage to the syncro is permanent . then you have to slow down the changes or force the shifter. neither would be required if people only used the clutch correctly . this can only be fixed by replacing the sncro rings during a gearbox rebuild . use the clutch dummy its cheaper.
heavy trucks with boxes like road rangers have constant mesh gears , gears are in mesh in all gears to the out put shaft all the time , cars are not syncros guide car and light vehicles gears into mesh in order to change ratio .
I use to do that to a 4 runner I had you'll grind a few gears every now and then other than that never had any problem with the gear box can't see it causing any premature wear or any major problems. You'll get more life out of you clutch as well
Tappet
It's not a crash box. You'll bugger the syncro rings in time.
As previously stated, a good skill to have although changing down is where the real skill is at.
Handy for when the the clutch slave or master cylinder pack it in. You'll get yourself home.
muc the truck
you have payed no attention to the brass particles the oil when you do a gearbox change making the oil sparkle in the light. these brass particles are like speed pumps in your bearings and get chewed up . at this point of time it damages the bearing surface and before you would have required it if you used your cluctch correctly your up for a set of bearings for your gearbox or you could just flog it of to some poor sucker like most do.
many people think driving a car with a leak clutch slave is ok or even a broken clutch cable and this is just fine as it keeps automobile manure factures , bearing manufactures and gearbox specialist in business just as long as your not paying.
