Mullos
Gday guys 'n' gals..
I have an issue I can't seem to figure out that i need some help with...
We have a 100 series TD and when under 'load' a ticking/tapping/clicking noise can be heard on and off at different times...
By under load i don't mean towing or loaded up with gear... I mean while accelerating (up or down hill and along the flat)
The noise itself seems to be governed by the 'wheel speed' and not engine revs and sounds as if it's coming from the middle of the car around the box and transfer case... I almost feel as if I am sitting on it...
To describe the 'ticking/tapping' noise - you can just hear it over the engine and tyre noise (muddies) and it sounds like there is a rock stuck in the tyre lug and when it hits the road you hear that 'tap' sound... kinda like that but metal tapping...
I have had a look all over the under body and can't see anything that could/would be making that noise under normal driving conditions...
Could it be a uni joint?? no idea what they sound like when they start to go... never had anything to do with them before.. wild guess...
Do gear box's and transfer cases tick at all when getting old?
Any suggestions to help try to diagnose this will be greatly appreciated..
Cheers,
matt
Cheers,
matt
