Clay Mud / Dust? Removal
wedgie34
Hi everyone. After a little dip in a mudhole of some horrible super-fine clay like muck, it's all over the place. It was about 1-2mm thick even under the vinyl flooring, where it got INSIDE the ute. I have managed to clean it all out with a hell of alot of persistance inside, before replacing all the underlay/sound/heat proofing material.
But the chassis, and in the engine area still has almost a "staining" from this stuff.
Does anyone here have a relatively easy way of washing all this crap off?
Much appreciated!
Joe
G'day mate. One way that usually works for me is to spray on some degreaser and let it soak in for a couple of minutes then hit it with a high pressure water.
vitara94
lol the joys of mud.... mate i have been trying everything to clean my motor down, but nothing works, its baked on... when they acid bathed my head it came up schmick... so im guessing it takes more than just degreaser and high pressure...
oznog05
Yeah, Its a bugger! The best ways I find to clean it, is attack it before it gets dirty. I spray the engine bay down with WD40 before go out. This help to combat it!
vitara94
now that sounds like a great idea... but once the damage is done(baked on) it seems impossible to get it off
kjs
if its on the painted sections on the exterior , baked on dirt and dust can be removed with normal paint cleaners such as mothers or meguires , bit of elbow grease required . For the undercarriage you can get ct18 which is a chemical wash ... should work but remember to dilute it.
bmurray2250
I would clean it with the Gerni but have it on ramps to make it easier access. Make sure you manually clean the joints and grease it them if possible
wedgie34
Found the ct18 soak, then gerni. worked great. Then followed up with Armor All Tyre Foam. Worked a treat.
Recovery Crew
another hint is to clean it as quick as possible when of or out of the tracks even if you just get the bulk of it.. the quicker you get to it the less time it has to bake on
i have the same issue. i read in the latest issue of 4wd action that ct18 (truck wash) is the way to go, yet to try it out yet though..
billolga
When it comes to dust, after a big trip I put the hose into all the gaps in all the doors & "Flush the dust out" - I do this several times -:cool: - IT STILL DOESN'T WORK!!! :eek: - MUD NOW, from the trip STILL comes out. :D
PTCX
I spray the worst of the mud off with pressure washer then I use a 50/50 mix of C-18 and degreaser sprayed on through a foaming gun(Karcher),let it soak for 5 minutes and hit it with the pressure washer again.That works well for me.
And I agree with Recovery Crew,getting it off sa sson as you can helps.
A couple of before and after shots.....
