Choosing a brake controller which one is OK?
CENTIPEDE
Hello all, I need to install a brake controller in my 4x4 for my Jayco, Flamingo Outback. Any recomendations ?
Thanks Luca.
Grey Ghost
I've got the Tekshona Prodigy in our Patrol and the lower model Tekshona unit in my Ute for towing our Jayco around the tracks, either one seems to work really well but in the Prodigy the auto levelling feature of it does make it a lot easier to setup and adjust, especially for tracks when you don't want the brakes grabbing as hard (and locking up) as they would on black top.
Pure Yobbo
I also have the Prodigy works a treat - also easy to dial up if you need to for certain applications,
When I was looking around about 12 months ago people I spoke too with the Haymen & Reece were removing them & changing to the Prodigy. Maybe they have upgraded the Hayman & Reece recently?
frosty
I've got a 10 year old Hayman Reese controller, still works fine, Just ask Big Rwig.
Brisey
I have the Hayman reese as well & works well.
Food for thought though is on some newer cars as with my cherokee the manual on switch on the controller can cause problems with the engine management. The cherokee apparently has two circuits in the brake switch & the engine management determined that there was a fault becaust it detected one circuit & not the other & logged a fault code. The dealer said that it could have caused the engine to go into limp mode as it thinks the throttle is stuck open.
Bri
CENTIPEDE
Thanks for all the feedback, I think I will settle on Tekonsha Prodigy ,$159 on ebay.
