Chirping Noise in rear end..??
Watt
Hi guys, as the tittle says I have a new "chirping" noise in the rear end somewhere..
it isn't consistent and is most obvious when i speed up to around 30-35 km/h then back off the accelerator the noise turns up in the rear.
The rear diff fluid is fine and there is no play in the driveline.
Checked the spare wheel but its all tucked away tight, sprayed the leaf springs with some lube around the shackles and had a look at shock bushes but cant recreate the noise except while driving.
I was thinking axel bearing or something to do with the drum brakes...
Does anyone have any experience with a similar bird chirping noise in the rear end.
2002 Toyota hilux. Wheels are negative offset which may be playing a part in the issue.
Any idea's??
Hayden.
Grumpy
I would definately look at your tailshaft universals, if you fail there it's obviously a bird that has found it's way into a nice safe place and it's just chirping to get your attention. cheers
Any idea's??
Hayden.
Hi Hayden
There bloody hard things to track down at times, jump up and down on the rear and it doesn't happen grrr, I just sprayed everything with crc, including up the shocks ,I would spray inside where the tyre Bolts to, maybe an inner/outer diff /wheel bearing etc.
Goodluck
prawns
Hmmm just to chuck it out there, my tailgate used to make the odd chirping noise (not just under braking though) and I fixed it by adjusting the rubber block on the cars tailgate lock mechanism (the rubber block which guides the tailgate to the lock mechanism on the car itself)
LowLux
I had the 2000 model and I had the same thing happen, I could be wrong but this was my experience.
It started as a slight chirp which I thought was the rear leafs/shackles getting a bit dry then as time went on the chirp became more evident, but usually under load, then one day towing the camper back from Broken Hill, that chirp became louder and started to turn into a gritty grind which just got louder and more gritty sounding and yup! got back to Adelaide and stripped out the rear wheel bearings to find they were shot n starting to turn blue from the heat.
As I said, this might not be your problem so may not be your answer, just sounds familiar to your description.
dno67
There's plenty of good suggestions here already but another culprit I've suffered from was one of those brake shoe retaining clips coming off and being ground away in the drum, started of squeaking and end up grinding.
Watt
Thanks for all the suggestions guys.. I have tried a number of things, checked the driver side drum this afternoon and the rear facing pad is wearing unevenly and but thats about the only thing that looked wrong, The drum itself was smooth with no sign of damage.
I'm hoping its not the axel bearing Lowlux but it does seem to be closing in on that problem.
hopefully i can get it diagnosed asap.
What was the cost of replacing the bearing and did you do both sides?
muc the truck
when you have one show worn more than the other its normally due to the hand brake riding rather than the shoes retracting by spring pressure keep away from the drum.
how are the wheel cylinders . to check them you need lift up the dust boot and if you see any fluid under the dust but they have already leaked past the brake fluid seal . thus weeping slowly , any small amount of fluid in the drums can make shoes squeal. looking at a brake wheel cylinder without prying under the dust seal is not checking them at all .
By the age of your car its well overdue to have the rear drums machined if they have not been done do so when you replace the pads , its a very good idea to do , drums , shoes and rear wheel cylinders all at once so you can for get about them for a few years otherwise you run the risk or wetting a good set of shoes with brake fluid down the track . They do become bell shaped and even out of round . even more things go wrong with them when there full of dirt and mud from paddock bashing .
Often a failing wheel bearing is still tight . some times tighter than normal . not loose allways as you would expect so consider investigating the wheel bearings again.
Watt
Thanks Muc, the brake cylinder on the drivers side has a tiny amount of fluid under the little rubber boot inside the drum but no sign of it leaking past the boot, not even sure if its a leak.. the cylinder look shiny and perfect under the boot.
The other point i have researched is the LSPV, as i fitted rear draws a while ago and recently a roof rack so there is an extra constant load of maybe 150kg.. (approx) Would this cause the LSPV to apply the brakes enough to mess with the setup?
I gave the handbrake assebly a lube up and this got rid of the chirping noise but i still have a slight clunk on some take offs and at very slow pace, around 20-30km/h. to me it sounds like the brake shoes are grabbing slightly. i tried adjusting them off a bit so ill see how it goes tomorrow but might need to get it looked at by a PRO.
i have a trip this weekend so i think it'll be fine until i get back..
Watt
Yep it was the axel bearing..!! went on a boys trip after getting the brakes serviced.. got to traralgon and the noise was back. Got to camp and it was a really obvious clunk when braking.
Took the wheel off and checked the axel play and it was moving around lots.
Had to leave the hilux at camp and jump in another 4by for the action on the tracks which was disappointing.
Got it home in one piece but after taking the axle out and looking at the bearing im shocked that it wasnt picked up when the brakes were done.. Bloody dangerous!
At least now i know what an axle bearing on the way out sounds like.
muc the truck
so you have totally pucked rear brakes then. despite what some one has told you the outer seal is simply a dust seal . nothing more . the inner seal is what keep the brake fluid away from the dust seal . Now that you have told me you have brake fluid touching the dust seal you brakes must be replaced as it burns into the shoes as it leaks and reduces its braking coefficient dramatically . the fact you have a weeping seal means you have lost mtrs off your stopping capability. I am very surprised you didn't spot the wheel bearing issue while your were in there with the brakes.
Watt
I've never seen an axel with a stuffed wheel bearing so When i checked the axel play before getting the brakes looked at there was about 3mm of in out movement and no sideways play or noise so it seemed ok.. the trip really took its toll and upon getting to camp the sideways play and the slushy sound was obvious. might do the other side in a few weeks to be safe.
Ill keep an eye on the brakes too.
Thanks Muc.
old_aussie
Banned
I think it's funny the things I read on here the last time a clutch was put in my hilux the fly wheel was faced off with a flap disc on a grinder :p:p that was a long time ago done my front disc's recently same way ummm good brakes now :p:p:p:p:p
My old VR holden got the same treatment :eek:
muc the truck
Thanks Muc.
3mm of movement
mate if your going to work on your car yourself , stop doing it blind .
buy a workshop manual (cds are cheap ) and you can print off the page you need so no books get greasy. be the best 10-15 bucks money can buy.
specifications are included . had you read this you would have know what to look for .
Some times the axle shears off at the bearing when the bearing is worn and running hot . some time the entre axle comes out and your left with a tyre on a pogo stick at the traffic . You better check all your wheels . none should have any side ways movement detectable by feel . This can be done without jacking it up by vigorously shaking the top of each road wheel in and out with no brakes applied . you may need to park it on some grass so it will not roll.
muc the truck
aussie you have hideously barbaric approach to your cars welfare . I pity them.
The enforcer would be shaking his head lol.
Please no one sand your rotors and fly wheel with a grinder. flat spots can occur and this causes the piston on the caliper to vibrate when braking and damage the caliper piston and seals. causing loss of brakes and brake fluid to splash up on your paint work at the least .
Rotors warp and get waves/groves in them from everyday use and once they are on there second set of pads they are often over .5 of a mm out of square and thus increases your emergency stopping distance . you can not tell if the rotors are warped by eye . when there really really bad the pedal will pulse under your foot up and down on really heavy braking (not abs pedal pulse ,warped rotor pulse) . this can destroy an abs modulator costing often upward of a grand to fix.
Rotors need to be either machined true on a lath or rotor cutting machine or more preferably replaced as most pads these days are so good and aggressive that rotors are often useless and out of specifications at only 100,000kms . many cars these days are requiring new rotors each pad change . rotors are really cheap compared to a decade or so . rda and pbr rotors are usually around 40-60 bucks each for a car and about 100-130 for a 4x4. Same goes for drums , they do not last for ever and need to be machined and periodically replaced just to have the same standard of braking the car was manufactured with.
there will be a stack of you that will say mine are original and done over 300,000kms etc but have you hade a dial indicator on them to prove you have the bare minimum brakes your car can potentially have standard.
Those wanting better than standard brakes go for slotted rotors and Qld Friction material pads Hpx or 4wd. And for drums keep them square and smooth to with no grooves from sand an rock embedded in the pads.
old_aussie
Banned
Oh yeah i've done the axle seals a few times as well never replaced a bolt use the same ones but hey I love my Holdens & Toyotas next time i'm in Townsville i'm gunna get your address off ya & say ge'day muc that OK :confused:
480,000 my VR commodore did before I sold him most people can't get 100 k outa a commodore .
Hilux 504,000 I think I treat my cars pretty good :D;)
