Chinese Tablet
Hi, My Chinese tablet has just decided to, on each time I startup ( after 6 months ) reboot to all factory settings. I have lost everything.
Any thoughts, on why????
whitehillbilly
LowLux
Only 1 thought...it's Chinese! Sorry, can't really help ya here but. There are other members that are more tech savvy than myself. Good luck.
jimdapom
I repair phones and tablets for a living. We get them come in from time to time. We normally just advise to recycle it and save up for a brand name device with a warranty. Its probably a software glitch or board fault.
Sent from my GT-I9300 using Tapatalk
jimdapom
One thing to check though..... make sure none of the volume/camera/power buttons are stuck down or missing the click. Most devices have a button combination you can hold to reset the device. Could be that
Thanks for the reply,
I HAD to buy the Chinese Tablet, so I could compare a $100 one against the Kids, I
pads.
7 inch screen, 8GB internal memory, 16 GB card slot. GPS/WIFI/BLUETOOTH, also voice search.
The GPS had worked really well with a couple of Nav apps downloaded from Google Play.
I also found the Android system to be much easier to use compared to the Kids Apple system, but maybe that's an age thing!
I contacted Zenithink to ask there thoughts. Its the C71A model
Thanks for you time.
Maybe there is a button stuck somewhere. With the buttons on the sides, it could be easy to bump.
It has a 12 month warranty. so have contacted the Australian seller.
whitehillbilly
pads.
whitehillbilly
Generally from my experience it usually takes two buttons to do a hard reset, power plus volume. If it's only happened once it could have been an accident.. If it's happened a few times it becomes an issue
Also if the Android updated to a later update that could cause it too. Go to settings and look in about device, take note of the Android version..
Goodluck with it.
Found a manual reboot in settings.
Downloaded forum sites,avg,Navy apps. And a few other things..
Everything appears to stay after restart. Time comes up correct,, and it finds my WIFI,without having to reset passwords.
Fingers crossed.
My music is also still there
Thanspks for your comments.
Whitehillilly
Everything back to normal. Almost
jimdapom, the tablet is telling me the memory is nearly full. But I have less on it than before
Maybe stuff iss still on the tablet somewhere.
Not sure how these tablets work storing info
I am a technno idiot.
It is similar to the ram/HDD setup ?????
Could my ram be full as this is where I put it, but the HDD is empty, hence not enough memory to download new apps ????
Thanks for your replies.
The Zenthink link earlier shows my tablet specs.
Whitehillbillly
cookie64
Thinking about your original issue, there is possibly a button battery in there to store all your BIOS settings, if this is getting low or flakey it is possible this could be your cause.
Have you tried doing a restart from software?
just some thoughts
cheers
cookie64
Holdown the power button and then swipe to shutdown, unplug, count to 5, and plug back in, then hit the power button again and see if all your stuff comes back or if it has reset again.
cheers
prawns
Thinking about your original issue, there is possibly a button battery in there to store all your BIOS settings, if this is getting low or flakey it is possible this could be your cause......
If it was a computer with those symptoms I would replace the cmos/bios battery without a thought - the symptoms match exactly (losing all custom settings etc)
I would assume phones work the same? probably alot harder to get apart though :D
Nothing is stored in RAM permanently mate - every time you switch off its wiped clean - its temporary storage only which programs use to run in when you start them. If you worried your ram is full a reboot of your phone would wipe it for a clean slate everytime
the "hdd" being full or not shouldnt affect losing custom settings either
If a reset of your phone doesnt work I think cookies on the money with the battery if they have them anyway hahahaha (I would assume they would - its not your normal phone battery it will be a tiny watch style battery on the circuit board inside)
Thanks for all your help.
I used the reset button again. Memory problems sorted, all programs downloaded.
Chinese tablet working again.
Even the GPS seems to be picking up more SAT's.
Whitehillbillies
