Chief oil
peejaycruiser
Anyone using Chief oil from superchump? Getting close to needing an oil change and I'm effectively paying $140 for 20l of Nulons High Torque oil. Since the Caltex depot seems to have shut down in coffs harbour I can't go back to delo 400 without being bent over the counter at their servos.
dno67
I've been a loyal caltex user for a lot of years and am now finding myself in a similar situation with our local supplier changing to shell and the nearest distribution centre an hours drive away and now also only excepting credit card payment, I'm now looking for an oil to replace Delo 400 and some others I use.
I have no info on the chief but am looking at changing to Super RX as a multi/mixed fleet oil, not quite as cheap as delo but @ $123.00 for 20Lt from super crap is affordable for me.
peejaycruiser
Penrite is dearer than the Nulon I'm using, last 20l drum of Delo cost me $111 which was a big jump from the drum before that cost $89. Which is why I changed to Nulon, but while cheaper to buy each change it works out dearer over 20l. Chief is a little cheaper again but I'm not sure if it's enough to warrant changing to. I would prefer getting oil in the 20l drum rather than buying 2 10l. 10l only leaves me a dribble in the bottle after each change whereas the bigger drum gives me the option to carry a 5lt container of it.
I really want to go back to Delo 400, I will have to see what the truck shops want for it I guess. Might be easier to just buy 2 containers of the Nulon and be done with it.:D
dno67
A single 20Ltr is the smallest amount I purchase at once. Not uncommon to buy 2 or 3 twenties in one hit, usually 1 or 2 engine oils and a 85-140, 75-90 or SAE 90 gear and a Hyro 68 or 2. Apparently
Caltex has won some huge contract in the Pilbara and are not that interested in the retail supply according to my current supplier.
peejaycruiser
I prefer 20l drums, gives me 2 oil changes with spare oil if needed. Will have a look for delo at an acceptable price or maybe switch to rx super or rimula x since it's readily available at superchump.
peejaycruiser
Thought I would update. Went with rimula x r4 and so far I'm very happy with it. Apart from seeming to have lost a couple of horses from the paddock.:eek: Will try rx super next change and compare the two against each other. Maybe I'll find the time to make a specific run to chase up some delo supplies I can afford.
phuaky
Have you checked out local truck shops or car dealers?
I live 50km (1 hr) from my nearest Caltex depot. I got my last barrel of Delo 400 from my local Toyota dealership (service centre) for $120. When you factor in travel costs and time it is still a reasonable price.
chris_stoffa
Gulf Western - If Supercheap have it in your neck of the woods , comes in 20 litre plastic drums , Aussie company , competitively priced, lots of products that meet or exceed vehicle specs and I use nothing else in all the vehicles.
Products
preems
I run Caterpilar 15w-40 in my triton, so far so good. One of my workmates has been using it in his Navara since new and with no problems.
20lt drum is about $120.00
I hear a lot of people say I'm using a new brand of oil for the first time and I'm happy with it. Is that because the engine hasn't blown up lol,or its not rattling its tits off ?? but won't the correct oil of any brand in the vehicle do the same thing , how do you know your new chosen oil isn't doing long term damage. I've always used Penrite, to be honest to scared to try anything else now. But is it warranted ??? . Is it good marketing to make us feel like this..
I'd have thought water in the fuel is a much bigger issue to stop an engine but how many have a third party water pre filters..
phuaky
I'm pretty sure it's just all marketing. All oils have to be manufactured to meet or exceed clearly defined standards. If the grade of oil you use meets or exceeds manufacturer requirements then in theory you should be good. Penrite is definitely marketed more than Gulf Western/Delo/Caterpillar and this is reflected in the price. But if the extra cost also comes with bonus peace of mind then why not?
chris_stoffa
If it meets or exceeds then I'll be damned if i'm paying for advertising campaigns :D, same with tyres.
dno67
Exceeding is not always a good thing, if you buy secondhand and the engine has been on an a lower spec oil a change to a more up to date oil can lead to high oil consumption.
Oils that have huge market share are quite often brought up to newer standards so as to maintain there current sales while also gaining new sales.
muc the truck
Have you a cummins dealer near by , they normally are good on fleet oil . last time I bought some it was under 100 for 20 lr. 15-40.
peejaycruiser
Not yet, don't get enough time when we go to town will have to pick a day when not got anything else planned.
Products
Have tried xdo before, was a concern everytime I pulled the dipstick it would run off the end like water.
Not sure if there is any here, not that I've been expressly looking for them either. Will have a look out for one.
And if you have an Izusu dealer near they often do 20lt Castrol for $100
Will chase up who they are.
:D:D
macka17
Don't know about those cheaper mineral oils.
I've always used Full Synthetic.
Buying by the 20 ltrs as above. From depot's it's around same price as buying good quality ,
not the cheapest mineral oils from servo's.
I use Castrol Magnatec Professional diesel Full Synth. 5-40. last drum was around $170
It's recommended for a lot of engines.
Does Wife's Honda Civic. my D-Max. prev 3ltr Patrol and I put it in my prev Navara too
I can/could do changes at 15 or 20k if wanted. but stick to the regular 10k and it still feels like new
when changed.
Seriously. The added protection Full Synth to suit your motor gives you. specially if you work it. is way over what any Mineral or mix could ever do.
It'll give you (providing it's not a clapped out or tired donk) a quieter. Smoother.
less smoke and quite often more economical truck to run.
chris_stoffa
Macka,
Don't know about those expensive synthetic oils.
Just what is "Fully Synthetic" - Mineral oil with additives, most oil, if not all has some.
If you check out this link you will find that Gulf Western Oil will have a oil that will suit all your vehicles. And many more.
Gulf Western Oil LubeDesk
Other brand oils will be the same. Synthetic or otherwise.
I for one won't pay 170 bucks for 20 litres of oil when the equivalent can be found for 30-40 bucks cheaper ( GW Euro Syn Oil)
Diesel Engine Oil
As said previously, I'll be damned if I'm paying for their advertising campaign
cheers
