If you turned off before chichester dam - Thats the Bandon Grove entry
(straight onto dirt - wangat trig road)
But you can go a couple ways from there....
From Wangat trig road you may have turned right onto skimmings gap road and followed it until you hit "frying pan road" intersection - where you turned left and kept on this road to get to frying pan campsite (Just before frying pan campsite there will be a right turn to get to coachwood, or go straight ahead and frying pan driveway will veer off to the right - while if you go straight ahead (veer left) instead it heads back towards Telegherry+Currawong campsites and then onto Jerusalem carpark past those
If you just stayed on wangat trig road instead and didnt turn right onto skimmings gap road - you would have followed it a bit passing the jerusalem carpark on your left, then you would have turned right onto middle road, passing "Telegherry picnic area" on your left, then immediatly through a creek crossing (underwater concrete causeway) where you would then immediatly see the turnoff entry to "Telegherry Campgrounds" on your right side (currawong campgrounds is in there too - just blow straight through telegherry campgrounds and you will come to a gravel creek - currawong is on the other side of that creek)
but to get to frying pan you would have blowed past that entrance to Telegherry and kept straight ahead instead, 10mins ish later you would hit frying pan entry on your left, with coachwood entry just past that
YMMV lols my bad memory - I got a photo of the jerusalem carpark turnoff if you want me to email it I think the GPS is embedded ...hang on this is easier (never actually seen that waterfall but Im led to believe you park in the jerusalem creek carpark and walk in from a local mate?)
Heres where I was thinking anyway for jerusalem falls hope its not a bum steer - Perhaps theres yet another way to get into frying pan Im not aware of - Im not a expert by any means either just been there a few times now I guess (to frying pan specifically - but have stayed at them all)
<edit> sounds like you took bandon grove then veer right onto --->wangat trig then veer right onto--->skimmings gap road, then veer left at the frying pan road intersection (the 1st way I explained) you would of had a nice cliff edge type view from your right side on skimmings gap road eh?! (that road scares the crap out of my wife lols)
If you want to hit jerusalem creek faster for a look, dont turn onto skimmings gap road coming in - instead veer left (as in option 2) and you will pass the carpark not too far up I think
