Gatti
I have installed my first dual battery system on my 1990 4 Runner Diesel.
It's the Matson system from Supercheap (not then best I Know)
http://www.supercheapauto.com.au/on...attery-System.aspx?pid=361561#Recommendations
Everything seems to be working fine, but I have a couple of questions.
The install manual says to run the headlights etc to flatten the battery to make sure the system disconnects the dual batteries.
I did this until the main battery was struggling to start the car. I figure the main battery can go flat from the headlights despite being a dual system as the headlights etc are connected directly to the main battery not through the Matson?
Then when I put a multimeter one each battery when the car is running again, the main battery reads higher than the second battery. I guess this proves the system has disconnected the two batteries as it should?
After running the car for a while they both then read the same voltage , so this would mean the system has put them back into parallel once the main battery has reached the minimum voltage amount set on the Matson.
A few newbie questions but I just want to make sure I;ve done it right before I head out camping and end up with a dead starter battery from running my 50l Waeco.
Here's some pics of the install
