muc the truck
A friend ask me to repair his landrover Discovery as it had a worn out tcase bearing on the front drive shaft and shook the steering over 100kms per hour when overtaking . At the same time i replaced the universals in the double cardinal joint and replaced the centre bearing in the drive shaft too as they were original and long over due.
he was quoted close to 3k to rebuild the tcase and the front drive shaft elsewere. But the only sign of play was at one bearing . just the front output bearing.
On the landrover discoveries unlike almost every other 4x4 you can replace the out put shaft bearings in the car with out splitting the tcase apart.
Now since some one liked my internal bearing pullers more than i did and i rarely used them i decided to have a go at using coach screws instead. all i did was aply a large dollop of grease to the bearing , drill two holes into the bearing race between the balls on the slowest speed so filings are traped in grease on the out side of bearing . then inserted coach screws and used a normal puller . purchased a brand new seal and output flange along with all new bolts and lock nuts ,universal joints form PADDOCK SPARES IN THE UK for under 150 bucks .
The inportant part was not to replace it with the same bearing . I used a heavy duty bearing thats hand asemmbled with more balls . its not heat pressed together like the flimsy shite bearings in most gearboxes these days . Its about double the price at 88 dollars from the loacal bearing shop but so worth it . I replace any bearings i can with these heavy duty style bearings as bearings are the cheap part. labour is the killer.
so for well under 250 worth of parts the problem was fixed
