Changing tyre size
Sam61sam
Yo ,
I have 31x10.5r15LT on my hilux atm . ( cooper st) by the way. )
And i want to put on 33"s cooper STT but they are the 33X12.50R15LT this means they wont go on my current wheels ??
Traveller
33 inch tyres would want 8 inch wide rim at least, and you may need to extend the flairs to cover the wheels to be legal. Will the motor push that size along ok? Speedo will be out a bit too.
Sam61sam
It should push along ok . Will be abit slower . So are you saying those tyres will fit on my current wheels ?
ERASER
You most likely have 15x7 inch rims atm. The 33x12.5x15 will fit but they really need to be on a 8 inch wide rim.
You will also probably need to do a diff ratio change as the hilux will struggle to push 33's along.
freekygeez
Sam,
You've probably already spoken to TJM but I'll go ahead anyway.
Are your rims still stock or aftermarket? (shouldn't be much difference in markings)
There is sometimes a marking noting the rim size, like on my jack it says '16X7'. Have noticed not all rims show this - if they stock then try the specs part in your manual.
All in all, your rim size is almost certainly 15X7 33's will fit but a 15X8 is ideal, also, watch for scrubbing if your car has small arches as this can happen when 33's+ are put on these type of cars.
dudelux
As said above, if your current wheels are 15x7, then I would go and buy a set of 15x8 wheels(they arent expensive, around 60-80 a rim), and put the 33s on them, alot less chance of breaking a bead off road.
You will also need to make some flares on your guards to cover the extra width that these will give you, to keep the law off your back.
Will your engine cope pushing 33s, hell yes it will, its a Hilux!!.
What engine is in your Lux??
I have an old 2.4diesel and it pushes 35s along, its slow, but it has always been like that. Your speedo will be out slightly onroad, so thats something to be aware of.
If you are finding that its alot slower on road than before, then you can change your diff ratios(centres), for better gearing.
Im going to change my ratios from 4.5 to 4.8, which should bring the gearing back to almost stock(and thats with 35s).
If you have any questions, hit us up.
Sam61sam
Jeeezzz thats alot guys . Plenty of good stuff in there :D Will be getting a different set of rims for my muddies and keeping my A/T as well
