Challenger After market Radiator
atowen
Hey!
After trying most things to curve my overheating problems the mechanic and i have come to the conclusion that my radiator is just not efficient enough! So with this I'm now starting to hunt down what next steps are in larger after market radiators; anyone have any suggestions?
And on a side note the challenger only gets hot when working hard, running a secondary electric fan helps when doing 4 Low work but the past few days (fully loaded + roof rack and mid 30's) has seen it getting hot on the freeway to :( . Its never overheated and if you back right off the temp will drop from 3/4 down to 1/3 fairly quickly.
Whats been done:
Full flush and clean
New thermo stat
Pressure tested
Water pump checked for flow
All hoses checked (and where replaced start of last year!)
The mechanic dosen't believe the pump cavitating and that it only leaves the radiator.
Thanks Anth
rickgq
sounds like a blocked radiator, exp if the cooling system was rusty in the past or some dick has worked on it and used to must silicone and its gone thru the cooling system and blocked the radiator..... rememeber genuine is best for engine parts, mitsubishi didnt release the car from the showroom over heating.... so id chase up an genuine radiator or an after market genuine fit replacement.
Jarh73
Has the radiator been pulled apart an "rodded"?
If the cooling system is in good condition it should not overheat.
Have pulled the radiator out and looked for blocked fins? I know you have been in a few bog holes! There may be mud coated all over the cooling fins.
Also the airconditioing condensor could also be blocked preventing air flow.
Just a normal radiator flush does very little.
Justin
mitschal02
Ours also got hot on the last outing, we had it sitting for a bit with the aircon going and also doing a fair bit of low range work.
Didnt over heat just got very warm but once we started moving and had a steady pace it was fine, also was the only time it has done it.
Always been fine just doing normal driving though.
atowen
We have a winner lol! The first shop that the mechanic sent it to seem to be a bunch of knuckle heads, radiator was 25% blocked with the top tank showing signs of cracking / fatigue! Hopefully all is good now!
Thanks everyone Anth
rickgq
Good to hear mate, alot of radiator mobs are to lazy to pull the tanks off the core, all they do is blast water in reverse flow and still charge the price of a full clean, then they wonder why they go out of business
