Jacked Surf
Cargo Barriers - Scrapped Not Going To Run One.
Rear Cargo Cage.
Hi i have a quick question on the rear cargo barriers.
Currently i am modifying a 60 series cargo barrier to suit my toyota surf. i have chopped the sides off and welded new box tube into the areas where the outer tube has been removed.
Where do you guys have the top brackets mounted to on your 4x4's.
Are the Rear Seat Belt Bolts in the C Pillar, a strong enough location to mount the upper cargo barrier brakets. as the surf doesn't seem to have any other mounting locations .
Otherwise would i need to make a long peice of metal to go to the rear most tie down bolts that are located on the floor.
Edit - Idea Scrapped. not going to run one now.
Rear Cargo Cage.
