DX Cruiser
Just got a Samsung 10.1'' tablet. Can anyone recommend a car mount? Im affraid the windscreen suction type will drop off when going bush.
Cheers.
Cheers.
Ive got mine fitted into a rubberised case and then I just stick it against the instrument panel face with a 10c piece blob of Smurf Poo .
Works a treat, cheap as chips and it hasn't moved yet
I bought a ram mount carriage http://www.rammount.com/images/gallery/RAM-HOL-TAB25U/RAM-HOL-TAB25UIU3.jpg
but I have not decided how to mount it will a limited Colorado 2010 cockpit. Its cluttered . Has anyone use the ram mound no drill mounts that bolt to your seat bolts . I don't want it above the dash or in front of aircon ducts .
Swaggie could I please pester you for a photo or two of where it sits and which ram base you bought . I think there is 3 choices .2 are aluminium bendable rods the other is adjustable and articulates . I don't want to buy the wrong one . your opinion is appreciated as your cars is basically the same as mine . Thanks mate.Yes I have the same unit mounted to the passenger seat Bolt, it's been great..
I might try and get it mounted above the glove box , I have 3 kids in he back and they rely on the centre aicon vents to get air to them , povo pac Colorado only has front air vents. I will get bit of garden hose and flex it to where it needs to go and see which mount is long enough. Thanks for your input fellas.
so your saying its made so it can be shortened then ends put back on ?The Rod can easily be cut and bent out of the way etc..
