no its an old one that was in the car when i bought it but not to worry i went and bought a transmit module for $65 and soldered it in myself and its fixed it
thank everyone for all the advice
Yep, that was my problem. When I went back to the shop that sold me the radio, asking him to check my SWR after I set up a ground plane under my fibregalss canopy, he discovered that there was almost no output power. He told me that my output amplifier was blown up.
I think this might have happened when my antenna came loose on its base because I was too shy of tightening it up too tight. The first time I screwed the aerial on, just after I bought it, I used a small spanner on the hex nut at the bottiom of the antenna. But I must have done it too tightly, because when I unscrewed the antenna I ended up unscrewing all the bits in the base plate. Was a lot of mucking around trying to pull it all apart and fix it all up again.
So I decided to just do it up firmly without a spanner - just with my bare hands! Problem was that I reckon it was not tight enough, came loose, and so next time I transmitted, it was like transmitting without an antenna. I think that was what 'blew' the output stage.
Luckily still under warranty.
