I Have the Aquaqube. This is my take from owning it for several years plus research I did on the Coleman at the time.
The Aquacube basically works well for showers and washing water. It won't get water hotter than 52 degrees or about 30 degrees above the incoming temp, whichever is lower. So no good for making coffees but ok for washing up or showers.
If I'm next to a decent river, I have a 12V caravan pump, 50m of collapsable fire style hose and use it that way. Endless showers. In winter and early spring the river can be about 5 degrees, so the output is 35 degrees. Great for showers but no good for washing up. There are 2 reasons why you can't do this with the Coleman which is why I went for the Aquacube. 1)The water must be super clean in the coleman - no river water or it will block up apparently ( going by forum posts, not real experience) and 2)The Aquacube heats when it sees water flow but the coleman heats when the switch is on so you cant use it in a remote heat situation as easily.
If you just want to get a bucket of water and heat it for a shower, especially with river or bore then I think the Aquacube is better. If you want hotter water and more fine control over temp then the Coleman is the go, but you need to use high quality water, which in many cases means bringing it with you. It would be interesting to see what a long term Coleman user has to say about that though.
