rob_macca67
Guys... for those Electrical gurus...
I currently have an MPPT solar regulator mounted under the centre Console & a 160w Solar panel mounted on the roof. This car doesn't get driven too often and is parked under a Carport making the roof solar useless.
To solve this, I'm thinking of buying a separate Solar Panel to leave out in the sun to charge the batteries in the car during the day. To do this I was thinking of installing an Anderson plug at the rear of the car where the cable would also run up into the Solar inputs of MPPT Solar Reg under the Centre Console and plug the Solar panel into the Anderson Plug to keep the batteries charged.
Now, my question is what size cable should I run from a 160w Panel up to the MPPT Solar Reg mounted under the centre Console?
I'm assuming as long as the cable is rated to carry the current of the panel it should be sufficient? Voltage drop shouldn't really be an issue due to the high volts output of the Solar Panel - Would this be correct?
Thoughts??
Thoughts??
