Buying a used Grand Vitara Auto - Help Plz!!!
N.T.
After careful deliberation I am seriously considering buying a Grand Vitara. This will likely happen pretty quick and I'm not quite up to speed.
The reason behind my decision is mainly because I'm after an auto and the pricing on the used GV's are quite reasonable.
3 quick questions
1. The first thing that came to my attention is the crazy amount of engine choices. My price bracket doesn't allow for the diesel. But out of the
three petrol options of 2.4 4cylinder, 2.5 6cylinder, and the 2.7 6cylinder which is the best for the power to economy ratio or are any of them lemons???
2. Is there any thing nasty I should be aware of or to look for when purchasing a GV around 2002 to 2006 with around 80,000 - 130,000 ks in the auto.
3. Is this rig going to be o.k to lift 2 inches put 31's under and go offroading in. I'm not looking to enter it into the next tough truck comp but will it do some decent low range work with out smashing tie rod ends and cv's ect ect (my driving style won't include hitting ledges at full noise)
Thnx in advance for any info to these 3 questions. I have got some great info so far from doing a few searches and will continue to do so now. Cheers.
rob_macca67
NT....
The 2.7 V6 I believe is a good engine & so is the 2.4 4cyl if u want a 4cyl, but if u look & post here :Northside Brisbane Suzuki 4x4 Forum your questions, I'm sure someone will respond with a suitable answers....
The years your at u will need to confirm that it has a STEEL FRONT diff. The Alloy ones can tend to go bang when pushed hard offroad. The bigger the tyres, the more it effects gearing so u could go an Auto or another reasonable cheap option is changing the Diff Ratios to the earlier Vitara 5.12 ratios. These diff's aren't that expensive if u know where to look.
U will need some sill protection as in sliders if u are doing hard offroading, again they are easy to make. U can get a 2" Bodylift and instead it yourself fairly cheap too. I believe those engines have timing chains, so make sure their not noisy.....
cheers....
dschmeda
Hi mate,
I drive a 2009 2.4L GV , manual though. I really like the car, it is a good ride on and off road. the clearance is not as good as bigger 4wds, but if you drive carefully and you're lucky enough it wont be a problem.
The Diesel ones does not come with an automatic transmission, only the petrol ones, and the v6 are more commonly found in auto than the 4 cyl. this is true for the current model, the previous one I am not sure.
The fuel economy is not great but not too bad also, I am getting 12 - 12.5 / 100km in the city and around 9 in highway. I'll add a liter or or a liter and a half for the auto.
I hope I helped!
prawns
Just as a "general thing".....if your buying a vehicle around the 100,000km mark check if they run a timing chain or a timing belt
If it runs a timing belt check if its already been replaced with the owner and perhaps evidence of such in his workshop book or a sticker under the bonnet
Generally belts need to be replaced every 100k and perhaps the cost of getting one fitted should be factored into your budget if applicable
