Peter_Pan
Hi There, new member here!
I bought a 95 4runner RV6 (3L Petrol) that's been raised and had 33's put on it. I snapped the front diff on a recent outing which was probably a mixture of inexperience and pushing too hard... and now I need to replace it. I'm trying to avoid a costly rebuild (this truck was cheap and it's a bit of a basher) and source a second hand unit.
The previous owner swapped out the standard rear for a LSD with ratio 1:3.66 (he's 99% sure)
Front was apparently the original.
I need to source a new front diff (preferably whole front end that I can just have swapped out rather than servicing the existing one) but I'm not sure how to find a diff with the right ratio, or what's going to be compatible.
Will the correct front diff ratio be stamped on the outside?
What wreckers do you recommend I contact in Sydney to find a replacement?
The original owner suggested I look at swapping out the front end for a 1st gen runner SAS. Not sure if that's worth looking into
Thanks in advance!
Thanks in advance!
