I am starting to planing on building my rearbar and rocksliders. Could i build my rearbar and rocksliders out of aluminium or would steel be preffered???
ya steel all the way
i have used 3mm wall 2" tube to make my sliders and 5mm C channel and flat bar to shape up my rear bar
it all came out strong as im very happy with them
You "could" build a rear bar from aluminum if weight was a serious consideration but aluminum sliders would wear through very very quickly and you would need a very heavy wall thickness too.
Just made some myself. 75x6mm flat for the u shaped chassis brackets. 50x50x4 rhs for the main slider and 40nbx3.6mm for the outer step/tube.
Also started my rear bar with tyre carrier today. 75x75x4 rhs for main cross bar. 75x75x8 angle for the chassis brackets that tie into the towbar and factory step mounting points
