Buggered Accelerator
Zukiman
Hey all,
Just a query from a less-mechanically-inclined member. I recently bought a second-hand Nissan Patrol (read recently as 5 days ago) and on the way to work this morning the engine light comes on and i get instant loss of power.. I pulled over and stopped the engine, waited a few minutes, then turned it back on - light disappeared. But had me worried, and i was less than ten minutes from home, so i thought i would head home and check it out.
Twice on the way back, exactly same thing happened, each time with loss of power but no engine noises, knocks, just complete unresponsiveness from the pedal.
Got home, ran through the usual suspects, checked water in filter, check lines, cleaned electrical contacts, all no luck, any attempt to run up the throttle past 1000rpm brought out the engine light. Other than that, no issues. Let the engine run for twenty minutes at idle, no light, foot on the pedal - engine light.
Next door neighbour is diesel mechanic, had him scratching his head. Finally rang the dealer i got it from, no warranty but said he would look into it and do something for me. Ten minutes later he rang back and said the acclerator pedal module was faulty, need to replace the whole pedal assembly. Had it happen to others he knows about, one just before xmas, a 2009 model with about 50k on it.
So i am getting it towed down to his mechanic, and he is splitting the cost of repairs with me, which he reckons is about $500 for the unit and ten minutes work by his mechanic.
My question is - Does this all sound plausible? He described the problem exactly, in more detail than i had given him, since i just said engine light and no power, he described the pedal response and sundry details which all concurred. He said it is a common issue, but none of the Patrol drivers i have spoken to have heard about it.
By the time i add in the tow and my half of the repair bill, it is cheaper than getting it repaired at my local mechanic, since even that would require a tow. Not a good enough mechanic to do it myself, and the neighbour is more used to truck and bus engines, and wa snot confident of doing it either.
billolga
I am not up on the Common Rail model - but on the older model (Mines 2003) you can read the fault codes with a piece of wire.
Does the problem happen when you PUT THE FOOT DOWN? (They can go into limp mode with over boost & reset when you take the foot off & re-apply - code 0406 ).
My most common falt - usually when in the bush on big trips is code 0707 which turns out to be crap in the fuel filter every time.
These codes on mine can be cleared with a piece of wire as well.
Accelerator can be reset as well but I haven't had to do it.
Alien d2
I don't know your rig but it does sound possible.
Lay mans explanation of the system(just enough to help understand).
The pedal will have an elecrical box attached to it.
As you use the throtle the contacts alter the voltage signal to the Engine Control Unit.
If no signal I'd expect the light to com on as yours does.
Should be an electrical plug and some bolts, not a big or hard job.
Have another talk to the neighbour as this is the system used on most trucks.
Zukiman
Update :
Got it towed to dealers mechanic, they pulled it apart and found that it was a secondary computer that blew, which controls among other thing accelerator input and throttle control. New module cost $1250, plus labour, so my part of the bill comes to $600.
Picking it up tomorrow.
