BT 50 bigger tyres
Chriso100
Hey all,
I'm after any info on Mazda BT50 bigger tyre size. A customer of mine wants the next size up from 265/65x17. Standard height and front bar. What do the BT50 owners out there have that's a little bigger on standard rims?
Doesn't seem to be many options out there.
Chriso
mac_man_luke
Guess your talking about the 2012+ model?
265/70R17 will fit easy with no issues. 285/70R17 will fit but minor scrubbing at full lock / full compression e.g. hitting a drive way with some speed
mac_man_luke
265/65R17 is a pretty common standard size these days, just about all the utes run it if they come with 17s.
Big Woody
9 months ago I up-sized the tyres on my 2014 Ranger to 265/70/R17's. (original size was 265/65/R17)
I went for a reputable brand and fitted Toyo AT's and it has not been a good experience.
The car has since had 3 wheel alignments trying to correct the tramlining and I have since spoken to someone who fitted them to a 200 series and had the same problem with the car wandering all over the road.
I also expected an increase in fuel consumption by increasing the diameter but this could be an issue for some people.
My consumption over the first 60,000km with the original tyres generally ranged from 7.5-9L/100km.
Since fitting the larger tyres it ranges between 9.5-11L/100km.
(Note these are real figures not in-car computer figures).
6 months ago I also fitted BFG Muddies to our Prado in the 265/70/R17's and love them. Very road friendly for a mud tyre. Road noise is a bit higher but modern cars have good sound insulation and hardly get driven with windows down on the road anyway so it doesn't worry us.
When the Ranger is due for its next set I will definitely be going to BFG's.
I hope this info helps.
mac_man_luke
Remember when calculating fuel figures to correct the odometer readings eg add around 8% for 285/70R17 (33s) to the km travelled.
Big Woody
Yes I factor that into my calculations.
In my case the odometer is out by 5% and speedo is out by 3%.
Part of my reason for increasing the tyre size was to fix the speedo error that the Rangers have from new. Mine was out by 8%.
Spooner
I just put a set of BFG A/T's KO2's on mine today , stuck to standard size 265/65 x 17 , so it won't interfere with ESC or other things , I really wanted BFG M/T's but at 265/70 x 17 decided its wasn't worth the hassle ,
As long as they work , that's all I care about.
