Bravo - Intercooler upgrade
chris_stoffa
Just did an intercooler upgrade on the 03 Bravo
Was at the wreckers hunting a headlight and spotted an 06 Ranger that still had its intercooler in place
3 minutes with a 10mm on the Dewalt and it was out. $100 it was mine.
( Important that the mounting plate is grabbed also ( 3x 10mm bolts ) and it came with a mesh guard aswell - Bonus !
Took it home and 45 minutes and a couple of trimmed rubber hoses and its in place.
Gotta be the easiest of upgrades besides a headlight globe upgrade :D
Does it make a difference - on a 30 minute drive I noticed that it seems to spin a little harder at the top end , seems to pull from a tad lower in the rev range but the main difference is that when the revs are kept around the 2-3000 range seems to be quite a bit more responsive. It does make a difference.
And the reason - the old unit was 14cm x 32cm ( total area 448sq cm ) the new unit is 21cm x 35cm ( total area 735cm ) - a 30% increase
Worth the $100 and the almost non strenuous effort to put it in :)
phs
You should see a little better fuel economy as well
It would be interesting to see the ET's before and after
chris_stoffa
The way I drive :eek: , highly unlikely I'll see it :D I tend to make it spin and stay on the boil.
I don't have a ETG so I'll never never know , but would be interesting to see if it has an effect.
Ive just bought a pk ranger intercooler too, after seeing this post and another person who's done the same. Ive also got a new 3" exaust on its way and a brand new standard size turbo but with billet wheels that provide 10% increase in air flow.
mauriceb
It would be interesting to see the ET's before and after[/QUOTE] Now you can increase boost and adjust fuel to match using a AFR meter or get it tuned . I'm running 20 psi in my ph 2.5 with low etg's well under 500 c and cruisers 200/210 c on flat ground . Thought about upgrading intercooler to PK model however already have my setup cruiser. These little 2.5 's a very nippy motors however I must say I'm not overly impressed with the torsion bar suspension find it very bumpy to ride in .
Ive got no gauges as yet probably get some once i start installing everything next week or so. Yea there great car i love mine. Ive just replaced all my suspension as it was stuffed. I went with a full pedders kit. Trakryder foamcell struts front and rear, pedders leaf springs in rear and pedders torsion bars. Got my original height back plus some.
mauriceb
You mean shocks not struts. 03 couriers should be same as mine ,Torsion bar front suspension, very primitive.
