brakes, fading
knucklehead
hi all
91 2.8d
went to watigans today, great time fun wet muddy slippy, but on my way out needed to pump brake pedal to get it working,
was fine before, haven't inspected it yet will do tomoro, (just all tukerd out)
any thoughts ????
will tell what i find?? soon
adrian
mac_man_luke
Did you just have to pump it once then ok? if so the callipers might have just been pushed back by junk
If not you might have a a leak somewhere or sucked water past a seal if it was hot when entering water.
muc the truck
that's very wrong information .
If ever you get a soft pedal some thing is seriously wrong with the brake system and needs repairs .
mac_man_luke
if your pads get knocked back then you will get a long pedal once to reset the position and then it will be normal.
Can also happen if you have too much end float in a live axle setup
Look up pad knock back
Can also be adjustment in drum brakes especially if they get muddy. Quite easy for them to stop self adjusting or delayed adjusting but this is generally a bit more gradual.
muc the truck
Look up fix your vehicle then . Like I said before if your brakes go soft fix it . DONT SAY ITS OK .
Gavo
I understand where you're coming from. Brakes are serious game.
However make an attempt to have some tact in your replies.
You may not realize, but your replies look like a grumpy, foot stomping, cranky bugger stamping at a keyboard while shouting and beating your chest.
Even if you've got best answer in world, it's basically impossible to take it serious and onboard when your replies are so blunt and arrogant sounding.
Here's a great example, pretend I didn't write anything above, and all I wrote was this.
"Look up manners Mr Know-it-all"
adrian222
Judging by the age of your lux I would say its time for a new master cylinder I am speaking from experience.
Adrian.
jump into your car with the engine running stand on the brake pedal and leave your foot on it with plenty of pressure if the pedal slowly sinks toward the floor you have a fluid leak somewhere, if so find it ASAP and top up the reservoir before it runs dry.
If the pedal stays firm at the bottom of its travel give it a fluid flush and bleed.
Could also be old lines that expand when under pressure and hot.
Could have just had brake fade from overheating
knucklehead
hi all, its a bit of a few things,
age, and previous owners, an me,… there is a now a leek at the rear connection right side,.
having spent good coin, fixing most of it (and a shite load of fun) OK, its brake time,
now were do i go Hmmmm up grades,... or new standard. well start with bradded n extended , vented or solid, 6 piston callipers, ones with red paint O.M.G.
well who has what on theres an why, i will stay disc up front an drum on rear, ps i do like red
adrian
muc the truck
Even if you've got best answer in world, it's basically impossible to take it serious and onboard when your replies are so blunt and arrogant sounding. Gavo he said it was ok to have to pump your brakes one time . then justified it with mechanical and maintenance issues. Pumping brakes- there is something wrong and
telling someone with brake issues its ok is worse and then justifying with more mechanical and maintenance issues Just said to me - fix the vehicle . beating my chest like king kong
I am so glad he found the problem and not just drove it thinking it was ok and just a Toyota thing .
knucklehead
hey guys
settle down, its 20 oddyrs old,
I'm the working poor, its all i can afford, i fix when it breaks, big deal,…
im in my 50's now been out n about plenty, 30yrs doing the motorbike thing,…
and I've noticed that on forums, people don't say what they would when face too face,
adrian,…
chilax n enjoy life it is precious,
Campin40
I will bet my left nut that while driving round in the wet and the mud on your trip to the wattos, you have gotten water and mud into the front hub area and as a result chewed out a wheel bearing. This results in to much play at the wheel and moves the brake clipar as well. When you push the pedal it pulls the wheel into line and then a second plush will firm up the pad on the rotor. As you drive a few hundred meters on down the road the wheel bearing will loosen up again and the brake pedal will potentially go soft again..
Jackolux
and what do you been by that comment,
be up front, don't be shy, if ya got a problem, get it off yr chest
adrian
Well it's simple Toyotas especially Hilux are known to have crap brakes , I have owned several , I have just sold my current Hilux a 06 D4D , it's brakes were pathetic right from day one , I have a few mates that own Hilux's , all will tell you the brakes crap.
Have a look on the Hilux forum there is any amount of threads complaining how bad the brakes are and looking for ways to improve them .
And yes over the years I have tried different pads , rotors , rear shoes had it looked at by a few brakes specialist all said that's as good as it gets .
I have just bought a new 4wd , in the process of test driving different vehicles I gave the brakes a real test ( panic stops ) all had very good brakes except the 76 series Wagon , was not impressed with it at all . I didn't bother to test drive a new Hilux .
Some might think the brakes are ok , until you really need em that's when it shows .
I totally agree now you've explained it a bit better ;), come to think about it my Hilux has been bullet proof and has done many hard yards. Yet going down hill in 4wd low I can get out the drivers door and walk along side the vehicle which at times is fantastic. But brakes isn't Toyota's strong point for some reason, I always put my Hilux into a tree, bank especially on slopes if I need to get out...
Jackolux
Isnt a big rock under the back wheel OEM with Toyota handbrakes:D
Yep Chris they should come std with a big rock in the back .
When I bought my 06 D4D in early 07 , I didn't even give the brakes a thought , thinking its a modern vehicle 10 years more advanced than my 2.8D I was replacing . How wrong was I the brakes were no better than the 2.8 the hand brake even worse , can you believe that ,
Took it back to the dealer complained , waste of time , have you ever tried to tell a Toyota Dealer their fantastic , best there is Toyota is not up too scratch .
Now ask me about the bloody injectors
...or the LSD rear diff or the gearbox that can't use 5th gear when more than 350kg on the back or the front diff and all the recent recalls, although not so much with the 4by range but give credit where its due there parts are expensive but they are VERY reliable:cool::p
