Hi mate, mine isnt a Triton its a HiLux but hopfully this might help !!
mine is on the fuel side on top of the intake, see pic's !
like i said i hope this helps !![]()
HI mate what hose did u tap into and where is it located cheersthanks for the tips guys, i just did it using the t piece seems to be working well.
cheers
cut it all out , metal folder is less than 100 bucks . weld inbit like this that i found while im restoring a Torana
OK thanks mate but I need to know where the hose is located so I can tap into it for my boost gauge pic's would be good cheersdon't drill and tap anything into a intake manifold unless its off the car and washed out . otherwise your engine eats, chews and crunches the drill swarf and beds into piston rings destroying the bores....... and you guys think egr is bad.
take a photo of your turbo and put it up hereOK thanks mate but I need to know where the hose is located so I can tap into it for my boost gauge pic's would be good cheers
