Not a 4runner, but I did a cab swap on my 86 dual cab very recently.
Did it on my driveway by myself, with only some handtools and an engine crane for the lifting of the cab.
Its not a massively hard job, can be fiddly though, and can be very frustrating too.
My advice to you is.....
Before you disconnect anything, label every wire/cable with where it comes from, and where it goes to, if you undo a bolt/nut, put it back into its hole once the part is removed. That way, you can avoid having a bucket full of random bolts/nuts.
Take lots and lots of pics of where/how parts are located/mounted, this will help you when it comes time to put it back together.
Leave things like dash/underdash heater/fan stuff alone until youve swapped cabs, I found it easier to remove 1 item at a time and then fit it, with the knowledge of where/how it goes still fresh.
Unbolt every part you can, to make the body lighter when its time to lift it.
You can swap the cabs by yourself, but it would more than likely be alot easier with a couple of mates, quicker too.
When I actually swapped the cabs, I had the bonnet, guards and all doors off to make it lighter and easier to lift, the engine crane did it easy.
I spent around 2 months doing the cab swap to mine, but it rained for almost half that time, and I was also doing some rustwork to the new cab.
The actual swap was done over a weekend.
If I can do it, anyone can.
Theres quite alot of pics in my build up on here, feel free to hit me up at anytime via the PM on here. Ill answer any questions as best I can.
