Body or suspension lift?
Willow_23
G'day
I want to lift my courier 2" and just wanted to know what's better for it.
I wound the torsion bars up and it snapped the cv shaft and collapsed the diff housing $$$ will a suspension lift put the same strain on the cv's
Thanks
LowLux
Personally, I would do the suspension lift first. If your still not happy with the height gain you could then add a body lift. A standard 2" suspension lift should not do any harm to your vehicle so not really sure what you did or how you did the damage you mentioned.
it will only put extra strain on the cv joint if wound up to far .Hence why suspension suppliers have preferred bump stop clearances and install recommendations . Lost count of the times ive expalined and shown people why you do not wind torsion bars up .
But if you have been driving around with torn CV boots the damage would have already been there and by winding the torsion bars up more merely added more strain on worn out parts .
suspension lift would be better the body lift won't lift the chassis so no clearance gain where susp lift will
Basejj
Yeah go with suspension lift u could get diff drop brackets to lower the front diff reducing the cv angles
muc the truck
G'day
Thanks
yes a lift will cause the same strain as thats all they do is crank your new torsion bars up and ignore the manufacture settings on bumpstop clearance. most tortion bars are sold on false and ileagal pretntions by deception. please dont think i am harsh but
i am tied of multi million dollar buisness lying to owners of torsion bar 4x4.
if you dont learn by yor mistakes your a fool. because only a fool keeps repeating the mistakes and causeing breakage of cv joints , cranking tosion is evil on your cv joints. adding firmer torsion bars will just reduce travel and articualtion. thats fact. the only way to get that articulation back is to add more load to the car to over come the increase spring rate of the new torsion bars.
some times people just have to acept they bought a vehicle with limitations with the budjet they have.
forget the suspension lift on a torsion bar front end completly unles it comes with diff relocation brakets and control arms .
4x4 need suspension travel in both directions not just compression. every mm you go up you loose in down travel and that means as soon as you cross a patrols foot print your wheel goes off the ground and your now just a usless 2wd car.
Instead make up for your vehicles shortfalls by being a better off road driver . pick a line even if you need to walk it fist. drive in a maner that traction is not lost and turned ito usless wheel spin.
fit a front diff lock first as the first mod on stock suspension.
you wil be come the sneaky little unpredictable truck . Do NOT let the big boys in patrols and landcrusiers with 35s make you think your inadeqant and bully you into something that can cause mecahnical breakages trying to be like them.
you have a lighter truck that fits between trees the big boys dont, use your advantages . fit slightly larger tyres than standard but ensure they are still able to tuck up under the gaurds on full compression on full lock.
on a torsion bar vehicle a lift by cranking torsion bars is actually reducing its abuility off road unless you just do beach driving or follow patrols muddy ruts . you need the flexiest front not a stiff one that just provides lift by cranking the torsion bars to achieve it.
after market torsion bar is just a higher spring rate than that of standard . the torsion bars must be still set by factory level and distance from bump stops to ensure cv joints life but 4x4 shops dont care there taking your money on deception , all they do is crank them up too just like you have already done and killed cv joints so you get the magic tonka truck look and you feel all warm and fuzzy thinking you think you paid for a more reliable system .
a torsion bar does not raise a vehicle regardless if its a stock one or heavy duty.
what raises a torsion bar vehicle is
A COMPLETE DISREGAURD FOR MANUFACTURES WHEEL ALIGNMENT AND RIDE HIEGHT ADJUSTMENT OF THE TORSION BARS AND EDURANCE OF CV JOINTS.
Not to mention some cranked lifts brake the nationals code of practise rulles regaurding travel in both directions and bump stop mesurements.
unless you use a diff relocation lift kit you reduced your reliabulity and service life.
lift kits that inclued diff relocation brakets and control arms achive the lift WITH FACTORY torsion bar settings and factory torsion bars unless you require hd torsion bars because you carry more load.
all a after market torsion bar installer should do is set it up that of manufature specifcations of ride height and bumpstop clearence in both directions thus giving you the IDENTICAL RIDE HIEGHT AS STOCK STANDARD . you have all ready paid the price .
The real reason for SELLING new torsion bars higher in spring rate than you have is if you added more wieght and cary more than the average joe. a person that caries sfa on the back doesnt even need them if they add a steel bull bar because a person that caries 400 kilo of tools on the back all day 247 with no bull bar does not need upgraded torsion bars yet they are aplying the same wieght to the front end and maybe more.
fit 15"' tyres so you have more flex in the rubbber for low presure hard going situations like mud and sand. fit a diff lock if you want your car to be any better than it is and keep the front end stock. do not raise the back like some fools do as this causes less wieght on the back wheels and provides less traction . REDUCING 4X4 ABUILITY.
just aprieciate your vehicle and its limits and you will go further than you think.
buy bash plates if you hit bottom but try to pick a line that will reduce impact , dont just follow the mug in front
if your dead set on looks of the monster TONKA trck syndrome on a vehicle thats not designed for this just do the body lift . it wont help you anywere neer as much as a 500 dollar LOKKA WILL IN THE FRONT. Can you remeber when you were a boy how much suspension travel was on your tonka truck? sfa hey. well thats what you get when you crank a torsionbar front end with after market increase spring rate torsion bars. this reduces wieght on the ground on a front wheel when one wheel is higher than the other . that casues wheel spin and now to get past this you have to drive faster and thats when you break stuff. go for the lokka.
If your dead set on joining the big boys then purchase something with live axles and 4 coil springs.
Hate to say but including new torsion bars in a suspension kit is not and would not be deception of any sort .
There is a calculation to carry out wheel alignments on lifted 4x4s that any good aligner or 4x4 shop owner or mechanic should work by to realign lifted 4x4s . So you are saying a 4x4 ute with light load springs with incresed height will have less traction in the bush .mm really
So you are saying my workute which as some customers on here will say has rather heavy springs in the back - when unloaded in the bush will have less traction due to it sitting high with no weight over the rear . mmm
Does that mean my office chick and her hubbies hilux with trosion bars and sitting a bit higher in the rear 50mm lift and wound up torsion bars will not work well in the bush and be unrealible and have no downward travel . mmm I can tell you with new trosion bars and wound up some at the front it has slight more downward travel nice compression and front end alignment set back to near facttory specs . How did we do that - we used matched shocks to the toriosn bars -matched shocks to the rear spring suspension mob . does it work in the bush hell yeah.
And not all 4x4 shops jack the front end up sky high .
Also can you explain how 15 inch tyres will increase flex for hard going situations like mud and sand .
joebog
hhmmm!!!
Both of yas have points, BUT torsion bar suspension doesnt really qualify for raising
I used to have 116 series Alfas, that used torsion bar suspension EXCEPTIONAL road holding, BUT I didnt jump the car over boulders cause I had 6" 150mm of travel and thats it
with a beam axle there isnt CV joints, just drive shafts AKA tailshafts.
they have universal joints NOT CV joints that slide out of the "socket" end
Drive shafts have their problems too !!! like excessive flex in universal joints, plus the drive shaft "pulling" out of the output shaft of the gearbox/transfer case which is the same as rolling the ball cage of a CV joint RIGHT up to the edge of the cup drive flange.
WHAT it does, is EXACTLY the same as using a worn shifting spanner at a 30 degree angle, it WILL stuff the CV joint,
Although you dont want to hear it, if you want high lift try a beam axle front end, buy a kidney belt, buy $3000 worth of linkages to attach the diffs etc etc etc
I guess what Im trying to say is that there aint no free lunch
Joe
Hiya Mate
So what option do i have for a 2 inch lift on my 2004 IFS Hilux if i dont wind up the torsion bars..????
joebog
IFS front ends
same as me swaggie!!!
ya go as far as ya can, trying to gain as much of both worlds. Raise it as far as " IS DECENTLY POSSIBLE" We are not allowed to cut the guts out of the car and move diffs/gearboxes/transfer cases. So ya need DECENT advice EXACTLY as muc the truck has said !!
I have to agree with every thing he said !! as Ive had an exact same problem, BUT is related to GPS's NOT suspension
What I can say, is that Dobinsons in Rockhampton explained all of this to me WITHOUT selling me a few grand of extra bits OR bullshitting me.
What I now have is a very capable chinese bomb according to most bench seat drivers, even though I have a full leather interior 8 litres per hundred fuel economy and I havent busted anything yet. PLUS I have towed out with my lil tiny 2 litre, some very big mouths!!!!
regards to all!!
and SKITCH em muc the truck :D
Joe
muc the truck
Answer.
WELL straight off the mark you mis quote and miss the most important words.
I said torsion bar lift by cranking not just torsion bars because most torsion bar makers instruct them to be fitted and adjusted to manufacture specs not just what ever you think looks good not to mension the fact there incorectly sold to a poor guy thats relying on the truth. Most heavy duty torsion bars are sold to people that do not require them and now have a firmer less flexable ride , that might please the wife for round abouts in the city but not off road. not only that no torsion bar should be sold for only lift as it has absolutly nothing to do with lift what so ever. Ignoring manufactures specifcations on the tortion bar ride hieght and cranking the the ajsuter up creates the lift .
Now tell me how many sales would be lost if they just told the truth and said oh we just buy in after market torsion bars that you may or may not need and crank them up so it looks good for you.
walk in to most of the 4x4 shops out there and ask them what's required to get more lift out of my torsion bar front end ? Most will say you need a heavy duty torsion bar set up without even looking at how much adjustment is left in the factory torsion bars. Most of the time if you want a crude lift like this winding the standard torsion bars and a new wheel alignment is all that's required . Also they will say its much more reliable and proven set up but they will not say run the same risk of breaking a cv joint form the extra angle as winding it up at home the same height.
Most do not need heavy duty torsion bars to get the lift they think they want unless they have increased load , most of the time if there stock ones had faded new stock ones will do the job perfectly . also the extra tortional twist from the lift when hitting bumps because the bump stops have not been moved to remain the same causes premiture fade of the new torsion bars or in the case of a new vehcile where its just cranked on stock torsion bars the torsion bars do not last as long as they would if left to manuafature limited torsional twist . now for example if you have say 60mm travel in both dirctions and raise it 50 mm you now have 10 mm drop not 60 .now the potentioal compression is 110mm and this puts greater strain on the torsion bars and the vehicles chassis wel before it hits the bump stops telling the driver to slow tf down.
Answer. The very first step in the manufactures workshop manual for a wheel alignment on a torsion bar front end is to adjust the torsion bars to with in manufactures bump stop ride height specs. That's the sole and only reason the adjustment on the torsion bars is there APART FROM for the mechanics onwn protection when it comes time to replace them when worn out. And your telling me and everyone one else this step first wheel alignment step is ignored. Yes extra shims can be placed in for camber but that dont take the load off the cvs or correct the anges .
So you are saying a 4x4 ute with light load springs with increased height will have less traction in the bush .mm really .
Answer . for a pro 4x4 guy your not exercising much common sense here. We are talking about a IFS diff. What ever you take to get the lift you loos from drop, every single time one front whel now goes in a rut you have less droop, THAT means less traction. Now if you have a flexy rear end thats raise it can make up for some of the shortfall created by loosing the droop at the front but only if its flexy and not rased higher than that of the front.
Answer . Boy you are now really not exercising much practical common sense here.
A 4x4 with stiff springs and no weight to over come the spring rate of the springs to make them work to there full range of travel is less capable to one that is able to use there full range of suspension travel when ever one wheel hits a rock a stiff set up will often remove load off the other wheel and cause wheel spin . so yes your stiff set up empty is no were near as good as a more flexible set up simply because a stiff spring set up has more influence over the other axles and less likely to WORK INDEPENDANTLY. ever seen a pro trail racer with stiff suspension? I haven't.
mmm I can tell you with new trosion bars and wound up some at the front it has slight more downward travel nice compression and front end alignment set back to near factory specs .
Answer Now you not taking into consideration how much weight is actually on each wheel . 4x4 off road traction is paramount . raising the light end of a 4x4 higher than the heavy end removes the traction it had and applies that traction to the front because there is now less weight on the back wheels just like a wheel barrow when you lift the handles it transfers weight to the front wheels. Now since the front is cranked what lift you gave it you robbed it from the droop and since your rear axle is not alpying as much weight on the ground when one wheel goes into a slight ditch at the front its more likely to spin the rear axle and the front wheel thats now it its new reduced droop
Answer well matching shockies to the imbalance ride height can not apply more gravity to the higher axle to make it take equal share of the load. shockies cant transfer load from one end of the car to the other.
Answer , Yes that's true . lets hope you dont and lest hope you leave the customer with a level car in relation to the load they carry and knowledge that by you cranking there torsion bars up to create lift there aware of the limitations you have caused as well as the benefits because 95 % do not do all of this.
Answer . I cant believe you asked this knowing your profession. we are talking about a ford courier with most probbaly 16"'wheels.
fitting smaller rim diameters with the same overall diametre tyre gives you a inch more rubber to fold and flex between the trail and the rim if he has 16''s 2 inches more if he has 17" (unlikely to have 17s but i hope you now understand the gist) this means one wheel has less influence over the other wheels traction when turning in sand and folds over more reducing the amount of sand that is getting bulldozed in the front of each tyre. Every mud pit has rocks and undulations and when traction is already bugger all and one wheel hits a small undulation it influences the others and can often bog . a tyre with more give in it will affect the traction of the others less when it hits the rock or undulation and travel further.
most of the torsion bar 4x4 owners are misinformed by 4x4 suspension installers /retailers and then those that are still accept the car with its benefits and new risks and shortfalls THATS WONDERFULL AND THATS HOW IT SHOULD BE .
I would rather those that are running cranked torsion bar fronts to know and understand the pros and cons . 4wds are about traction , suspension travel and reliability. Any mods should improve those 3 not the other way around for the sake of the Tonka truck syndrome on a vehicle with built in limitations.
Answer well matching shockies to the imbalance ride height can not apply more gravity to the higher axle to make it take equal share of the load. shockies cant tranfer load from one end of the car to the other.
Answer . I cant believe you asked this knowing your profession. we are talking about a ford courier with most probbaly 16"'wheels. The bigger the ballon (air space) look at the army LARK tyre flex and small rim size in proportion to the out side dia. he cant go that big but he can improove things with smaller rim diameters with the same overall diametre tyre gives you a inch more rubber to fold and flex between the trail and the rim if he has 16''s 2 inches more if he has 17" (unlikely to have 17s but i hope you now understand the gist) this means one wheel has less influence over the other wheels traction when turning in sand and folds over more reducing the amount of sand that is getting bulldozed in the front of each tyre. Every mud pit has rocks and undulations and when traction is already bugger all and one wheel hits a small undulation it influences the others and can often bog . a tyre with more give in it will affect the traction of the others less when it hits the rock or undulation and travel further.
I would rather those that are running cranked torsion bar fronts to know and understand the pros and cons . 4wds are about traction , suspension travel IN TWO DIRECTIONS and reliability. Any mods should improve those 3 not the other way around for the sake of the Tonka truck syndrome on a vehicle with built in limitations.
Thats why i recomended the man buy a front lokka and bash plates. THATS NOT ROBBING YOU OF BUISNESS ITS ACTUALY REDUCING YOUR COMPETITION AND MORE LIKELY TO SEE THE CASH REGISTER GO CHA CHING . you should offer the man a good price on a lokka and bash plates .
Willow_23
Thanks mate my main reason for lifting it was so I can fit slightly bigger tyres without scrubbing. I'm definitely looking at diff locks aswell. Thanks for your help guys
Alot of ramblings going on . Alot of unexplanations in simple terms .
you say most 4x4 owners are misinformed by 4x4 shop owners / suspension installers /retailers -exactly where would you like me to start on missinformation given by some on here that has cost various customers $$ to rectify .
Never have we installed /sold /advised on a suspension kit that has not perfromed to ones expectations or exceed what they asked of it .
The only issues we have had and it is documented -has been a couple of people who had repairs carried out who had not carried out recommened repairs prior to a trip to the gulf resulting in breakage s .
and people changing load carrying duties of ones 4x4 after a suspension kit has been installed as in adding further weight taking weight off .
Ye we do wind up the trosion bars but to a satisfactory height and dont have a problem with it .
We do advise to some of young blokes to crank the torsion bars down a bit .
Swaggie reckon you missed what I was saying about lifts and torsion bars there mate .
Mr truc and who ever else Im happy to continue this discussion further as we have nothing to hide and stand by what we say but keep it till after easter as we are away and wont be able to reply to any further discussion till then
Angeloioc
Just get new bars and/or crank them up. Hell put in a drop kit and then make up for the difference in cranking. But do put in manual hubs. Saves cv's for when you need them. Problem solved. Remember that 2" is the max legal lift. CV's are items you should be checking before they break. Simple as locking the hubs and turning. I'd rather break CV's where they can be easily replaced and it saves your ears from the whinging you get from the passengers.
I have seen some people crank them up way too far and some other alterations (illegal alterations) can be downright dangerous.
In my personal experiences, the cranking up of 2" gave me more clearance and wheel travel remained the same -- on a 1994 Paj. None of this rubbish that mysteriously made my 4wd lighter on the rear -- oh I wish that could be true for the front at times.
Talk to your 4wd mod PROFESSIONAL as they live, breathe 4wds -- they have also seen and experienced all the issues.
Angeloioc
Yep. I saw a Hilux in QLD with well over 2" wind up. It looked like the thing was going to topple over and couldn't imagine the grinding of the CV's let alone stress on other items.
muc the truck
you did loose down travel so what you say is not 100% true and when down travel is what you need for a rut the lack of it can cause wheel spin.
part of what you say is so true , cranking with diff location brkets are a must as it saves componant falure and its the only way to lift a torsion bar front end with out making it weaker.
The other part None of this rubbish that mysteriously made my 4wd lighter on the rear -- oh I wish that could be true for the front at times.
Thats total bshit and taken what i said out of context. the wieght of the never changes just the shift of load from one axle to the other . surely you understand what was said about the wheel barrrow. the higher the handles are liften the less load on the handles and more on the front just like raising the tray of the truck with tall springs , taller than the front . the higher you go the more wieght you transfer to the front and remove traction abulity from the back to the front. when you need all for 4 wheels pulling there own wieght. might be ok to have a tray high in the air if you allways go up hill . its about centre of gravity
muc the truck
ramblings my backside , you just refuse to belive traction is lost with a stiffer spring rate. how smart is that idea. no very . mate incase you have not heard this before the flexier the suspension the beter the vehcile is off road. hint hint
I never said that you dont warn people of the risk nor did i say you get the rattle gun and wind those tarsion bars with tthe rattle gun untill they go up no more.
if you take the time to read my first big post on this subject i was saying most sel them for the wrong reasons . the customer will do as he pleases at the end of the day if he is told the corect ifformation he will probably make the right purchase not allways some acept the risk of a crank job with no diff relocation brakets and thats fine as long as they bujet for new torsion bars sooner and the posibulity of a broken cv.
many 4x4 chain stores will tell you , if you ask whats the best way to get a 40mm lift out of my new truck ? one of our lift kits with hd torsion bars mate is the most common answer . this part is the bshit.
Because as i have said before and you know this but most 4x4 owners do not is a torsion bar does not lift a vehicle at all stiff or standard a torsion bar has nothing to do what so ever with lift or ride hieght. you also know that the lift only happens by winding the torsion bars up so with this said there are thousands of people each year being sold stuff they dont need when ll they could have done is wind there original torsion bars up in the back yard 40mm with a tape measure and go get a wheel alignment. Maybe some new shockies too if there no longer up to scratch. Its a common misconception to drivers not mechanics to think that a torsion bar 4x4 needs heavy duty torsion bars to provide the lift . this is what i am trying to kill off.
not many 4x4 owners are mechanics and not many of the people behind the counter selling stuff for the wrong reasons are mechanics some of them just want profit some of them just say what they have heard some say before. Its our job to educate people to make the right choice. and as the old saying goes you can lead a cammel to water but you cant make it drink .
that doesnt mean you dont bother trying to save its life.
