4X4
Body Lifts
50mm body lifts will require some modifications for a successful installation. Gear levers will need to be bent and in some cases lengthened. Gear lever boots may also need modification to reduce the possibility of gear drop out from extra boot load. After fitting a body lift kit, the front and rear bar mounting points will need to be raised for best appearance. Clutch hydraulic hose, mounting points can also require shifting.
