Blown turbo seal OR blown motor
usfour
What a way to finish our 4 week trip,
Everyday check oil and general engine bay stuff nothing by week four 2mm down on oil, no worries , we decide to drive home from Ayers Rock to Callington sa (1600 clicks) stop every 2-4 hrs stretch nibble go, stop
At port aguta fuel up check oil damn down nearly to low mark, check leaks nothing, top up take 4l, put it down to sitting on 100 Kay constant, keep eye on exhaust , no sighn of burn even on take of after sitting, get 20 Kay's from home lose power slight up hill look back big black smoke hit neutral go to pull over and she screams into full song clutch 4th stall it, open bonnet smells hot and burnt oil , remove oil cap lots a breathing , lift air cleaner top and smoke pours out, pull tube to turbo half cup oil sitting there, looks to have come from breather of rocker cover by we're oil mark starts up stream of turbo.
Call friend tow home, walk away.
After starting trip with incidents did not want to finish it with one.
SO IS IT Turbo OR Engine
Will clean it , call help , by a lotto ticket cause I'm broke from holiday,
At least it was near home
80lover96gxl
Geez I hope om wrong but sounds exactly like what happened to mine couple of yrs ago.
Oil seal let go in the turbo and dumped a heap of oil thru the engine resulting in a 8k engine rebuild and 1k turbo rebuild.
This was no 6 piston
Which resulted in a 50thow bore of the pots and head was cracked beyond repair .
If yours is the 1hz id seriously be considering a 1hdtfte conversation, can be had for 7-8k nowdays with moderate k's and a puter and loom plus you'll need the pump.
If I had my time again this would be the road id go down for sure as there's just no comparison between the 1hz and 1hdtfte.
I hope its just your turbo thats failed.
Mine let go just the other side of Mansfield and cost me $1600 to get home.
Stupid Flanders
Sorry but what vehicle?
I am thinking turbo simply due to the sudden increased oil use. But if it hit huge revs then its prob not good.
Bugger!
MatOZ
Sounds like a turbo for sure.
Remove the glow plugs and crank the engine over for a bit to release excessive oil from the cylinders. Than do a compression test a see what results you get.
If the engine looks ok remove and clean the intake from oil and fit a new turbo.
Remember upon first start up have a piece of board to cover turbo inlet. If there is still enough residual oil in the head it might rev high, but if you clean everything it should be ok.
Best to be safe though.
usfour
Sorry she a 1hz with safari turbo only 145 Kay's , yeh have thought about hd update and even v8 diesel, but will try fix her up first has done really well so far, could do with some more torque (longer legs) .
Just wondering if the excessive black exhaust and lose of power may have been injection pump failure and oil due to high revs, still don't cover excess oil use thou.
Will make room in shed then try get one of other cars going for taking kids to sport / running round.
Holidays over
High revs were for5-10 seconds max,but only takes a split second to destroy a motor
dno67
When the seal fails it lets the oil pass into the air side of the turbo and ends up being sucked into the combustion chamber having the same affect as adding more diesel, which is what caused the excess
rev's. Unburnt oil will appear as smoke at the rear of the car.
If the engine has suffered damage it'll need a new or reco turbo anyway so would be a good place to start keeping whats been said above re the cleaning and checking for damage.
80lover96gxl
Holidays over
Yeah same set up as mine but had 250 on it when it let go, like yours scavenged oil for 5 secs at max rpm but did shit down when I managed to hit the key, sometimes they dont but the damage was done regardless of the short time maxxing out.
Were you using boost and pyro guages? I wasnt when mine popped but had them fitted when being rebuilt and geez its amazing how much you need to adjust your driving style when driving off the gauges, now I don't push it over 12psi and never over 500° post turbo, kinda sucks having alot more power now with the bigger pistons but cant really use it , even tho motor has been built for the turbo I still keep it under 12 psi, dunno guess im paranoid about it popping again.
You can pick up 2nd 1hz's for 3k that'll bolt straight in , might be a chear option.
Good luck mate.
usfour
Agree on the gauges have them and more, and watch them, even got the missus trained to keep an eye on them even while I'm driving especially when having a red hot go at something.
The gauges said nothing
Waiting on the push party to arrive
usfour
compression test, nothing for number three .
now to find a trustworthy engine rebuilder
not what i was hoping for and all at the wrong time, may be pushed into back of shed for awhile, no trips this season.
80lover96gxl
Bugga mate, took me nine and a half months to get mine done.
Seen quite a few fte's for around 7k.
mauriceb
us four, you certainly had a bad run on your trip , wheel nut at roxyb, split airbags on the french line and blown motor, May i ask a few questions what boost and EGT was your safari turbo running .You may want to consider the bottom end 1hd t parts upgrade ,ask 80lover69gxl about this ,secondly can you post the brand of airbags that split and why you think this happen as its quite rare ,were they installed incorrectly ,or incorrect air pressure ect ,just very interested in this topic ,thanks
usfour
Boost peaks at 12 sometimes but would normally runs at 10, EGT is pre turbo was sitting at 450/500 , airbags don't have brand but will find out, they were fitted by a well known shop and pressures set at shop at 17 and up to 24 to level out load, both split only pin prick on joining seam, the shop has said it very rare but have had others, reason no idea we travelled at speed to suit and watched road conditions,
Thanks for the tip on motor ,will contact 80lover for some advice.
Cheers Rod
Rod, bugger mate, hope it works out as best possible getting back on the road, and you find someone to do the work that will keep costs as keen as possible.
usfour
We'll not the update I wanted but lifted the head today, number 3 piston big hole all others cracked, valves bent, and messy head, looks like timing belt may have skipped.
Now the motor coming out total strip block and head and check all damage.
Then work out what to do and at what cost.
Sad
Diesel1
Toyota diesels have pretty reliable belts and tensioners unlike some other makes.
Was the hydraulic tensioner and bearing still in tack?
When was the last belt changed?
80lover96gxl
Geez that sounds familiar , apart from the timing belt bit,, mine was only 15k old. Did yours look like
this ?
Diesel1
Just read the whole post.
The timing belt would have jumped sprockets when the engine was screaming full tilt.
The engine hitting full noise would have been the oil in the inlet feeding it.
As I said in the last post Toyota Landcruiser diesel timing belts are probably the most reliable belt drive setups with 150000kms intervals.
80lover96gxl
Think its more a 1hz being turboed issue ,, while there are plenty of success stories out there with 1hz's having a turbo and clocking half a million k's without issues there are just as many horror stories about their early demise due to being turboed.
If I had my time again I would of put my 9k towards an ft or fte conversion rather than rebuilding my 1hzzzz with a few stronger components, live and learn I guess.
Fte's with puter and loom can be picked up for 7k these days, granted they may have around 200k on em but thats stuff all for these motors.
Diesel1
You can get quality aftermarket pistons and rods for aftermarket turbo 1HZs now.
Pistons have ceramic tops and low friction coating.
Rods are stronger for the boost.
Hopefully she is going soon again
