Bike Rack on Treg Hitch
foxeyes
Hello people
Wish to mount a Bike Rack onto towbar with a Treg Hitch coupling. Only problem is that the Treg Hitch has locating lugs on each side which will prevent it from sitting flat on the goose neck.
Cannot mount it to the trailer drawbar as not enough room/space to do it
Can I do either of the following or something else
1) Fit the bike rack underneath the goose neck with the Treg Hitch on top
2) Place a couple of washers between the Bike Rack and Treg Hitch
thanks
sschmez
I hit the edge of the flat bar for the bike rack with my angle grinder and created clearance for the hitch lugs. Didn't need to remove much - two grooves a few mm deep.
Stevo
sschmez
Can't really show you better then this while its assembled......
you rack is probably different anyway;)
Grind it or even drill it to make it fit as intended, I would anyway.
Stevo
