Best way to paint tray
coolstubbies
have a 2003 hilux, just taken out the moulded plastic tray liner, looking at what is the best way, in terms of lifespan and ease of maintaince and also in preperation for draw system to paint the tray...?
So the plastic liner is staying out or going back in..
coolstubbies
yes plastic liner is staying out, looking for a good base, rust protection for draw system i am putting in
was thinking of using black enamel paint
prawns
spray on rhino lining stuff? I had a couple mates with navaras and they got their entire tray+sides sprayed for protection - no more scrapes along the top of your ute sliding surfboards etc in which was their issue
Epoxy Flooring, Epoxy Grout | Rhino Linings
Goes on thick and leaves a "orange peel" type surface to look at it
coolstubbies
similiar, not so much surface protection, more for rust protection,looking for a product that i can apply myself, looking to save cash
prawns
I use this stuff personally for bits of normal spraypaint work - Seems to work ok but you might want some advice as to whether you want to spray or brush such a big area? (I have no idea :D)
<edit> Not sure Swaggie mate, could be - Theres lots of other companys that do similar stuff too, hercules? i think, lizardskins etc
Some of that stuff you can do yourself, but you would need a air compressor + spraygun I think (works out expensive if you dont already have them I suppose)
I'll have to pull up an old mag..
muc the truck
I use rino spray and still looks perfect after many loads like this.
There is also low pressure 20psi kits you can do your self , a stone guard gun is used and cans of 3m body armour just scew on . water based or turps based but the turbs based one is closer to rhino
matt88
I use raptor coat same as rhino liner. apply it with a body schutz gun. can get it from prestige paints at acherfield
phs
ummm very interesting i am keen to do my tray i was going to call afew places and get rough prices on a respray.
have you seen any work that have used this product ?
peejaycruiser
Not seen first hand, but quite a few classic car restorers have said nothing but good things about it. Have been thinking of grabbing their starter kit to do some work on the 80 and the trailer.
