I use cast iron . while its hot tip in some cold water with washing detergent , if its really baked on let it boil and clean its self . rinse with clean water and oil . most of the time it only needs a wipe out and re oil as cast-iron makes its own non stick coating unless you burn stuff.
we also use the same cleaning method on stainless steel so I don't see any reason why titanium would be any different . you will be surprised what dishwashing detergent will remove when boiling
Haha. This man knows.Hmmm.
Give it to the wife.
Then move out of throwing distance. And that all depend on how well she takes...
Our dog does this if someone leaves the dishwasher openI did catch my old man putting the pots on the lawn so the dog to do the pre wash cycle.
I think deoderants are ok. Anti perspirants have the ally in them. Do you treat the cause or the symptom???The alloy thing with pots was the old non coated alloy pots, the coated type is not a issue, if ally does cause brain issues we had better stop using most deodorants as well
recall reading somewhere its best not to use detergent on cast iron as it can be absorbed ... personally have found that hot water, scrubbing & cooking oil cleans your cast iron stuff well & keeps em in good knickI use cast iron . while its hot tip in some cold water with washing detergent , if its really baked on let it boil and clean its self . rinse with clean water and oil . most of the time it only needs a wipe out and re oil as cast-iron makes its own non stick coating unless you burn stuff.
Damn!! I forgot that!cast iron is best, a bit heavy, but no toxic stuff to scrape/ burn off. aluminium is supposed to cause alzhiemers,
I’ve got a titanium spork. I just wash it in warm soapy water. It looks and washes a lot like aluminium. I’d treat it the same way. Wash in soapy water.Hello everyone,
Just got myself a titanium pan from HPro and some titanium folding sporks from timberbrother on amazon for my next camping plan, my wonder is: what’s the best way cleaning titanium camping cookware? Anybody have experience or know how on maintaining them?
Many thanks!
