Best intercoolers
dirtyfun
Hi peeps,
As we are converting from 1FZ-FE petrol to 1HDT turbo diesel in our 80 series, we are wondering what is the best intercooler to use. There are those that have said front mount is better than top mount and vice versa. What are the pros and cons of both and if we do get a front mount where can it be installed as there seems to be very little room. Hopefully someone can help us to make an informed decision :confused:
Cheers.
muc the truck
when you hooting down the highway at speed there is not a massive difference but front mount still wins.
when your in low range 1st gear snail pace loaded up there is no argument to as which is better. Front mount wins hands down as its not soaking up the heat from the hot motor due to little air circulation. search this forum .
80lover96gxl
Safari front mount on my 105 alao, after some research the only downside I can see with a fmi is abit more turbo lag due to longer/more pipework, that and maybe more prone to damage from obstacles.
mauriceb
intercoolers
This subject was discussed a while back ,and can be quiet controversial The best front mount for the 1hd-t would have to be the Safari However a quality tested W2A Top mount will out preform it .The air to air top mounts are subjected to engine heat sink and some a actually useless .Including the denco W2A at higher ambient temps due to its miniture front heat exchange radiator and small water lines http://www.4x4earth.com.au/forum/other-miscellaneous/28648-cross-country-vs-hpd-intercoolers.html Read this next thread before you buy The official 1HDT Intercooler thread | IH8MUD Forum
phs
W2A top mount will out preform all of them
Can't say I am a fan of aftermarket front mounts they will block a lot of air from the Std cooling system if there big enough to do a good job + they are the first thing to cop mud caking as well and become open to being damaged
top mount A2A can be good but best fitted with thermo fan with in cabin switch
dirtyfun
Thanks for the answers fellas. Did consider the W2A but have heard that it can let coolant in the engine and as this engine has been totally rebuilt its a very scary thought. I was looking at getting a decent top mount A2A with a thermo fan.
Diesel1
Any engine with a water cooled intercooler is always at risk of this.
Many industrial diesels use this system as it is very effeient.
But poor maintanane can lead to engine damage.
I recommend if you go aftermarket air/water intercooler use quality poducts that have back up.
muc the truck
Yep a Decent size water to air heat exchanger will outperform a top mount air to air intercooler and its cooled by its front mount radiator. which as you say is the very place that is exposed . Its not really that badly exposed .
Heat exchangers are pretty good as long as the cooling system is up to scratch as it places extra heat into the cooling system than otherwise expected.
macka17
Reviving old thread. popular subject.
Talking front mount with all the extra piping.
I saw a Patrol somewhere. He had racks on.
And had what looked like a Intercooler along front of racks above windscreen.
Thinking about it. They wouldn't have to be much longer if any
than a long bonnet front mount.
Snorkel one side of screen. Pipes the other,
Definitely fresher cooler air, with GREAT airflow.
T'is a thought anyway. Well protected from road damage.
Possibly a fine'ish grill over front for birds etc.
Maybe somebody should make inquiry.
I found my 18inch, tubular aluminium Transmission cooler they use on Drag and rally cars by doing so.
Better than finned I reckon. and my one way catch can that fits under car,on chassis rail.
