best bit of camp fire cooking equipment
whats the best/most useful bit of gear, thats not too dear to use to cook on the camp fire? just some very very simple stuff like eggs sausages beans etc?
the reason i ask is i usually take pre made food like sandwiches, canned food etc but would like to start cooking on the fire.. looked on anacondas site.. seems mostly for portable stoves where i want to cook directly on the camp fire.
any links would help if possible too
cheers!:p
Gavo
Go to a disposables/camp store and buy a big round cast iron fry pan, or big rectangular cast hot plate. Should get a cheaper pan for around 30 bucks. Make sure you cook it in, or season it as commonly known. They usually have a wooden handle, so unscrew it and either leave as is or head to hardware store and put a long bolt in it.
I've just got a piece of steel plate I cut at work, had it for years.
There is stacks of sweet cast iron cooking stuff. From jaffel makers and of course the beloved camp oven!
Gunna
do i need an iron tripod or stand of some sort to go in the fire to sit the fry pan on?
this is the only thing ive found apart from all the iron dutch ovens
Camp Fire Cooker, Large
I use one of these, cooked everything from garlic prawns to a good hearty steak these cookers are only limited by your imagination.
The grill is good for cooking toast in the morning while the bacon and eggs are sizzling on the plate.
smitty_r51
we just have a cast iron grill plate
it fits perfectly on the 3 burner stove if we can't have a fire or just drop it over the embers...works a treat...
also been known to use it over the little wok burner on the proper barbie if i need more space :D
marty e
If you buy a bedourie camp oven you can use the led as a fry pan
Sent from my HTC One XL using Tapatalk 4 Beta
ULost2
Can opener!! :eek:
Matches!! :eek:
Great invention. Originally made because the cast iron ovens were easily broken when pack saddled in the bush and the weight factor was important also
I use mine at home also.
If I was forces to leave home with very limit stuff (had to carry it) the Bedourie oven would be on the list.
When travelling by myself this is so handy. Just wish I could find a non-SS one. Note 30 year old Engal.
My late father's quart pot also gets a plenty of use.
prawns
Mate Im really not sure your supposed to cook snags using Caltex Diesel oil :D
Bloody top job mate :) I would have your one over the one somebody else linked to at a shop which had the legs partially blocking the hotplate :D :rolleyes:
Great job mate
dno67
Great job mate
Thanks mate, those one's in the link can be a problem with the way the top of the legs
stick out when folded causing damage to other gear while traveling.
Delo's the good gear, leave's a nice oily film on your lips. LOL
hiluxdriver
Camp oven, and fire grill plate (a bit like this), interestingly enough, found at Anaconda . . . Camp Fire Cooker, Small
I just bought one of these and giving it its first run this weekend.
With the cast iron stuff, what is involved with "cooking it in" and "seasoning"? I have a couple of heavy frypans and skillets, and the bloody things have a light coat of rust after a few days, and no chance of cooking eggs on the pan. Is this normal?
ULost2
To season; as i remember it. Good clean, get it very hot>>add some cooking oil and rub that around with some paper towel held in tongs. Do that a few times and it should be like a non-stick pan. Remember it's VERY hot and smoky!! I have heard others adding salt.
Remove all the rust with steel wool before cleaning. Or fine wet and dry sandpaper. make it shine like new.
Don't scrub after use, usually a rinse in hot water will do. If you do it as soon as you finish cooking is best imo. BTW that works with most dishes also.
On most pots and pan labels there will be instructions to do it so have a read up at Rays.
profoto
I have seasoned a few with oil, burn it in pretty much then wipe clean, do it a couple of more times.
Not sure but I think salt creates a non stick surface.
TheLocksmith
Threedogs post said:-
I use cast iron but that is 36cm for that price, gotta be happy with that.
All my gear is for 4-6 ppl so that frypan would be perfect once seasoned properly.
Buy 2kg of salt tip into frypan and leave on heat, you'll have a non stick spun steel pan straight away
Maybe Utube will show a Chef seasoning a new spun steel Wok
Cant hurt any fry pan except maybe alloy, but works on spun steel and cast iron.
All my pans are seasoned this way then just clean as per normal,[No Soap]
Come Get Some - Sent from my iPhone
dno67
I'm surprised know one has mentioned the Oz Pig. I made my own version of this, mine's
called the feral Pig.
Great as a heater too.
