Beach driving prep
#1
Hi guys.
I want to start taking my 4x4 on the beach more often.
I've got sand recovery tracks, a compressor and tyre pressure droppers, and a shovel.
Anything else I should have?
Should I bother with the rust proofing sprays, or is that a waste of time?
Superdad
LT tyres and you're good to go. Don't be afraid to drop pressure right down if sand is super soft. Also, resist urge to speed, it's amazing the crap that can sneak up on you on the beach.
Just run the car over a sprinkler when you get home and avoid salt water at all costs.
Snatch strap or 2 a couple of large bow shackles, a good set of jumper leads I've had to jump start a vehicle once on the beach and rust proofing in general is a good idea.
red hilux
Don’t worry about rust proofing.
Just wash the car very well. Take the end of the hose off and push it inside all your chassis rails.
mikehzz
Rust isn't the problem it used to be, most newer car panels are galvanized now. Still, you shouldn't go driving into salt water and yes, it's pretty well mandatory to wash under the car afterwards.
Don't go snatching unless there are rated recovery points at both ends. Enough people have died helping others out of trouble. I'd go so far as to say only snatch or be snatched once you've been shown by a competent person who has explained the risks.
Airstrike
Seems like you're good to go
Road tyres are better for the beach than mud terrain as they can float over the sand
Take your right foot when you feel like you're getting bogged, so it'll be easier for you to dig yourself out!
I suppose it would depend a lot on the tread pattern of road tyres as well my brother use to have a lot of trouble with Pirelli road tyres that came with his Disco he would just sink in the soft stuff and I would quite often just drive around him with BFG or Kumho MT's and pull him out of the sand or help drag him through the thick powdery stuff.
I use to spend a lot of time driving on the beach and have had different vehicles on the sand a shorty 40 cruiser, hilux, 4Runner, 60ser cruiser, Disco, Patrol and never had any problems with mud tyres I think it's more myth than fact created by a 4WD mag quite a few yrs ago I remember reading it and laughing.
There may be the occasion that MT's might be a slight disadvantage and dig in but also there are times when they dig in and that can help to propel you forward but that can happen with any type of tyre other than that I have found they float fine on sand. I've also had a few different brands of AT's which have all been fine as well.
Airstrike
yeah agreed, different tyres got different tread patterns with some M/T being really aggressive. My mate's Hilux running BFG M/T and he does fine on the sand. I guess it all comes down to the pressures you're running + weight of your car
From what I know, Discovery have really crappy sidewall with big rims hence why they aren't the best. It'll be best to run a skinny tyre with good sidewall e.g. 70 or 75 with 16 inch
BlueCollie
I know Tred recovery tracks recommend a minimum of AT tyres so there is enough tread space for the tracks to work but otherwise any tyre seems to work on sand so long as it's deflated enough.
Hi guys.
I can't help myself on the car, same as the boat trailer and camper. After a trip up the beach and a good wash, all moving parts, bolt heads, springs, rubbers etc get a good dose of lanotec. All subframe items painted black or galv get a drink of penetrol. Simple things like wheel alignments become an issue with frozen bolts if you don't do basic maintenance. Ive spent most of my life on beaches.
RDM
I think tyre pressures matter far more than the type of tyre.
I spent a week on Fraser Island and the only recovery kit I used was Maxtrax and a shovel.
shanegtr
For any sand work the 3 most important items are pressure gauge/deflater for the tyres, shovel and an air compressor to air back up. With those items I reckon you can get through 95% of sand and deal with any bog. For a little bit more self recovery a set of maxtrax or similar are great (dont own a set myself) and a snatch strap and shackles are useful items but require assistance from another vehicle to be of any use.
2luxes
There are a couple of sand tyres shown here. file:///C:/Users/user/Downloads/militaryservicetyres%20(1).pdf One looks like some kind dual purpose while the smooth one is similar to the type used on military Landcruisers during a two year project on Stockton beach NSW that I was involved in many years ago. I have seen both types used on the Army LARC-LX amphibious vehicle.
