Bauer 62CC Chainsaw
smitty_r51
Ebay special
Took the plunge at thought for $159 delivered I would give it a shot.
20" bar with a 62CC motor, weighs 8.9kg according to the box
Ordered Friday, Turned up today (and we are usually at least an extra days postage being out of the metro area).
Double boxed.
Unpacked the chainsaw, took about 10 minutes to put everything together. One thing to note is the manual is online only, there is nothing in the box, although it is fairly straightforward to put together and start.
Toolkit and safety gear is through away, be ok for the kids to play with but nothing i would be using.
Filled her up with bar oil and fuel (25:1)
Adjust on the chain was tight to start with as was the first couple of pulls on the starter.
Started on the third pull, one thing to note there is no primer bulb on the model so you have to wait for the fuel to be dragged through.
Then started cutting, took about 10 minutes to reduce this,
to this, and used most of a tank of fuel.
Quick refuel and adjust of the chain and it started first go
Couple of niggles with it.
1 - The chain brake was very stiff and i could only get it to activate by giving it a serious whack, although the one time the chainsaw kicked it did activate...something to keep an eye on
2- Two full tanks of fuel and I could start to feel it through my hands, now this could be this saw doesn't have great vibration protection or it could be that i am used to lighter saws (12-16" and 30-35CC)
But overall i am happy, i can live with the niggles for the price of a single hire from the local hire shop of a Stihl, used it for two tanks of fuel non-stop about 40 minutes worth and didn't find the weight a hinderance and it cut straight through everything including a couple of red gum that i cut down the trunk to make flat planks (just to see if I could and the wife has been hassling me to see if we can do it)
Smitty
muffin man
I've got that exact model and while cheap and nasty it does everything I want. The starter cord on mine broke within a few weeks and they posted out a whole new assembly. At times it can be a bit difficult to start but that would be more to do with infrequent use I would think.
hiluxdriver
Was the same as mine also. I bought 4 extra chains so when I was on the last one, I'd send the others out to get sharpened. I found the piece with the chain brake didn't fit up very well on mine, all worked fine though.
smitty_r51
something to add, all the fastenings etc don't require specialist tools, there are no torx screws or random star shaped nuts, everything is either an allen key or a flat bladed screw driver.
MUX STX
After 4 years I am onto my second Bauer 20inch bar 62cc chainsaw.
Great value and frankly you can not go wrong with the price.
I have not had a chance to fire it up just yet but am confident no problems for a few years yet.
Ebay sellers can send the cheques to #@*&%^.............. thanks
Campin40
I've got the 82cc version. 24 inch bar. Had it for about a year and had no problems with it so far other than the chain supplied is pretty crappy. Replaced it with a husky chain and now stays sharper a lot longer rips into the timber like a champ. It's obviously cheaply made but it start easily every time and for the money you can't beat it.
MUX STX
What I really like is the loading up of the starting cord................Please explain
Basically you load up the starting cord so it sort of self spins after you extend to the full length of the pull, hard to explain, but very handy.
Sort of like recoil in reverse.
