So, both Batteries are connected and charging from the Ctek D250s dual from Alternator and SOLAR. Pumping in around 15amps from the Alternator at times on idle.
I just noticed that the most voltage from Batteries while charging is 14.3v.
Thought it would be charging up around 14.6v until it reached full charge.
Maybe Temp Sensor is restricting .....although it's not that hot.
Seem normal to you fellas? View attachment 76105
Read your instructions then you won’t have to guess. Max volts on bulk charge for that unit is 14.4.So, both Batteries are connected and charging from the Ctek D250s dual from Alternator and SOLAR. Pumping in around 15amps from the Alternator at times on idle.
Let me assure you that if an alternator only needed half of its output to power a standard, un-modified vehicle with no after market accessories fitted, then the manufacturer of that vehicle would only be fitting an alternator with half the capacity.I read the other day that as long as the charger draw amps are not over 50% of the alternator can produce then you will be ok.
That's where it is important to know what the standard alternator is in your vehicle is & what its output is.Let me assure you that if an alternator only needed half of its output to power a standard, un-modified vehicle with no after market accessories fitted, then the manufacturer of that vehicle would only be fitting an alternator with half the capacity.
Manufacturers don’t waste money on “let’s fit a bigger alternator so the owner can add heaps of shit which we won’t warrant anyway”
Yea, I agree but IMHO you missed the point I was making. Regardless of the actual capacity of your vehicle’s alternator, that capacity will only be sufficient to supply your vehicle's normal operating needs, and stuff all more, just a small safety margin. The manufacturer does not give you more capacity for free.That's where it is important to know what the standard alternator is in your vehicle is & what its output is.
They will be different for make & model so the answer is open to the specs, some are 90amp & then others could be as high as 120+amps.
You should do your own research on the vehicle you have & then you can make your own determination it what it can & cant do in that configuration!
No I got your point & that may well be the case but to me its just about the figures & not that manufacturers are tight arses where they can.Yea, I agree but IMHO you missed the point I was making. Regardless of the actual capacity of your vehicle’s alternator, that capacity will only be sufficient to supply your vehicle's normal operating needs, and stuff all more, just a small safety margin. The manufacturer does not give you more capacity for free.
