Battery/alternator light
Quozie
I've recently replaced my battery and alternator and now when I give my 99 GU a bootful my alternator/battery light comes on faintly then goes off. It seems to be when the vehicle lurches. It's almost as if it has water level issue (appears). Any ideas?
prawns
perhaps double check your electrical connectors are tight, and that your belts not loose, then grab a multimeter and check that the alternator you installed is outputting the correct voltage when the car is at idle (and revving) from memory my last car and bike it was supposed to output 13.8volts at idle (perhaps check a workshop manual/ask a mechanic)
If it aint outputting correct voltage its the regulator/rectifier usually? (which sometimes is actually part of the alternator itself, or somtimes they are seperatly replaceable)
cookie64
Sounds like your belt is slipping, Patrols have an issue with the belt tensioner so that would be my best bet
Colin
Quozie
Thanks guys, Will check it out this arfternoon, need to get it organised before our trip to Great Ocean Road next weekend. Don't really want electrical issues with a long trip like that.
DMGRangie
Seen this probblem alot with serpintine belts been worn out on the little ribs and v belts glazed up as sad before belts loose
muc the truck
serpantine belts fail prematurly with slack or worn out tensioners and idler pully bearings (check if they wobble with belt off) . if you know the age of your belt and its found to be the cause and its badly worn replace the tensioner with new belt , and dont keep that new belt foe a spare , toss the thing out , because by the time you need a spare belt a long way form home that one will snap soon down the road before you relise you didnt buy a spare just yet
people there is no use keeping old belts as spares, keep a new one under your seat.
I have driven the darwin to adelaide route a few times , twice i have stoped to help people with a busted belt . twice i helped them again when the old hagged out spare snapped a 1000 or more kms down the road. the odds dont look to good to me
Fishigan
Just letting you know that we've replaced a few Patrol belts with aftermarket ones lately. They have come back with the dreaded squeak. Ended up getting rid of the squeak by fitting a genuine belt. Apparently, it's a known problem with some aftermarket belts.
Funny how the light comes on at high revs??? Usually the other way around if it's a loose belt. Might be a bearing starting to seize up somewhere???
