G'day Steve,
Interesting idea mate, so the larger right angle brackets are made to fit direct to roof rack bars, and the 2 angled plate to various roof baskets ?
If so, then of course Ironman (and probably others) have brackets to fit to rack bars . . . mine ex Ironman are stainless 210mm long x 90mm brackets, that material is 25mm x 3mm.
I had to take 2.5mm off the edges of each of mine (x3) to get them to fit into the Thule type rack 20mm slots, a real time involved (and possible dangerous) job, using a 4" grinder with 1mm cut off wheel, then grinding wheel to finish . . . took a couple of hours !!
But, I think stainless is the way to go, I don't think mild steel would cope with the stresses.
(Mate, i'm a bit, no, a lot deaf, and didn't hear all your vid audio, so forgive me if I missed anything there about their materials etc.)
If you can make them to slot into the roof bars easier, I think people would buy them (at least if they know how hard it is to get them to fit, they might).
See my pics.
The other brackets.
Obviously an option, but I would suspect most would mount directly to the roof rack, or maybe mount a plate to the rack and bolt awning to that.
The angle probably isn't too critical as the awning will work the same *, even if the mounting has it tilting back a bit (it would be that little bit closer to the rack too without any sort of angle correction brackets).
* Unless angle is SO great that the outward arms can't come down enough with the connectors . . . hmmm, also with rain you DO have to angle the awning roof down a lot to stop water pooling, so you might be onto something here mate.
I'm not sure I would trust the slotted mounting on the brackets, to both the rack and the awning.
The slots don't look deep enough to me to get a decent washer on there, and even then I'd rather see straight out holes.
If these slots were alternating each other in direction then they could oppose any process of the rack vibrating forward or back from rough tracks, or an impact, etc.
If a awning / fittings were slotted in from the front towards the back for example, and you rear ended someone pretty hard, would the rack tend to possibly fly off forwards ??
Alternatively, if mounted slotting onto bolts back to front and you got rear ended, the forces might cause the awning / fittings to dismount ??
I think I would just go for plain old holes in them for sure fire fitting.
Good on you Steve for looking for a solution to a problem you feel exists in the market, I hope it goes well for you and you get this off the ground.
I have invented products and sell them daily, and it's very satisfying to know there are many thousands of items around the World that you have made / sold, filled a gap, and STILL the Chinese aren't copying them !!
