AWD vs 4WD
asfdaedf
Hi guys,
Does anyone know where can I find a list showing which car model is a AWD and which one is a 4WD?
I am looking to buy a 4WD with a 4H / 4L gears, but it seems there plenty of these shitty city SUVs which are all advertised as 4x4...
mikehzz
You can safely say it's 4wd if its got low range. A car with low range thats all wheel drive usually means you can drive it in 4wd high on the road without winding up the drive train. The only car I know of with low range that is iffy is a Subaru Forester.
Gavo
Probably best of just heading to your local Toyota dealer, they have an excellent choice, of real 4wds. FJ Cruiser, Prado, Hilux (single, dual and extra cab), 200 series land cruiser, Fortuner and of course the toughest of them all, the 70 series in choices of Single or Double cab ute, Troop carrier and 4 door wagon.
That's pretty much a list of new all the new 4wds worth buying right now. :D:D:D:D:D:D
Toddyh
Ignore all that and buy a Delica.
interesting advice Gavo, the only guy I have met and wheeled with that regularly does hard tracks in a 79 is selling his because he is sick of breaking stuff, spending a fortune to keep it on the road and the last straw was another starter motor and a month long wait for a new oneo_O:p
abw
That's a bit rich, coming from a Landrover owner:confused:
Haha, your just as one eyed as Gavo......just the other eye though.
nananut
If you look at the full specs sheet of the vehicle, it should tell you whether it has a 4x4 lock system which makes it a AWD or softroader or low range transfer case ratios for a proper 4x4.
D
Deleted member 69390
Guest
I have a 4wd that does not not have low range and is probably more capable than most other vehicles offroad.
It is a combination of capabilities that distinguishes awd from 4wd - first look at what the vehicle is marketed at.
Then look at things such as clearance, center diff lock or equiivalent, offroad TC vs road TC, fittings, and for most common 4wds hi/lo range/
Good luck
mikehzz
Some of the Amarok models do not have low range. Are they still considered a 4WD?
Tink
PC's crew car is an almost standard auto Amarok and it towed a trailer while loaded with camera gear cross country in the north Simpson. You'd have to say it qualifies on that effort. There are a few capable auto 4wd's around now that have no low range and sophisticated traction programs helped by their torque converters. Still, to be sure, a low range box is a dead give away that it's a fair dinkum 4wd.
muc the truck
Hi guys,
don't be scared of a allwheel drive with low range , your showing your novice side . this includes landcruiser and land rover both much better off road than there part time equivalent . driving the all wheel drive Is superior on corrugated dirt roads than a part time vehicle in 4x4. you must have heard the saying you drive to the conditions . Well when you are driving a allwheel drive on dirt roads (high range speeds) you will do it so easy that you wil be frustrated to death with the fella in the part time 4x4 drowning you in dust and slowing you down and just wish you could over take the slow bastard struggling to go any faster as he is driving to his conditions .
ian.c
Some time ago they banned Awd vehicles from driving on the beaches on Stradbroke Island, unless it has low range you can't get a permit as the rangers were sick of doing recoveries of ill prepared day trippers thinking these cars can go anywhere
Im sure an 8 speed Amarok would handle a bit of beachwork without the same problems, they might need a new definition of cars they want to ban.
callmejoe
Hmmmm.
I once owned a toyota tercel. 1985 (i think).. Rated right up there, like 2nd place out of 10 other best NOT 4wd.'s...
It had high and low range.... Sooooo would i know class that as a real 4wd... prob not.
Mind you it only cost $750..
ian.c
My brother abused one of those for years, tough little car, biggest test for a car is being owned by my brother who doesn't believe in servicing.
