I have driven both, and love the auto off road, steep decends can be tricky, but the trick is to drive through the brakes, low first and drive with 2 feet, that is to brake and accelerate at the same time, adjusting the throttle according to what the car is doing. This takes a bit to get used too, but is very effective.
The technique is to be locked into low range 1st and while still on the flat at the top of the hill, drive forward with the tacho reading 1500 revs. Now holding that accelerator position, place your left foot on the brake and slow the revs down to 800. As you progress down the hill you must not move the accelerator at all but change the force with your left foot braking to keep the revs at 800 until the bottom of the hill. If you should get some lockup you just ease you brake but do not change the right foot position.
The procedure works because you have a lot more torque at 1500 revs where you locked your foot into than at idle. This extra torque keeps the wheels turning to stop lockup while the braking keeps the speed under control. They say that some vehicles of small capacity will not be able to hold the 800 rpm so you have to find what is best for your vehicle.
I have not tried this yet but I think it has merit and look forward to trying it or hearing from someone once they have. Obviously you would try it on an easy hill first to get used to it and it will be harder for those that do not practice left foot braking all the time like they teach in advance driving schools which is why I learnt it a number of years ago
